Supershanks, thanks. Great stuff as always. Your hard work is appreciated. :up:
:shrug: yet :)Quote:
Originally Posted by diablos
So far with this it's like the X48T a lot of fun :)Quote:
Originally Posted by loonym
Done a bit of playing about with Turbo mode:-
Engage Turbo Mode:D
Examples
Turbo Mode 4,200 - 4,000Mhz 20x200 DDR3 x8 1,600
Turbo Mode: 4,410Mhz - 4,200Mhz 20x210 DDR3 x6 1,260
can you share your complete 20x200 setting?
Why DFI hasīnt packed Tri-SLI bridge with this mobo?
How is the Less cooling, and analog PWM doin? are there missing any bios settings? that the UT has?
I have , see 4000 20x200 Ram 8 = 1600 8-8-8-21Quote:
Originally Posted by Krautmaster
= Click Picture. Sorry:shrug:Quote:
See link above for full bios settings.
Cos unlike the UT it's 2x SLI not x3Quote:
Originally Posted by BulldogPO
Hi Infa,
Coolings fine had no issues was originally planning to lift the NB
Click pic for link
http://www.images.clunk.org.uk/revie...bo/nbclean.jpg
and mount a cooler and fan , but haven't found the need.
Ok, now I will order a board in 2 days, and I'm sitting here to find out, the giga UD5 has 10 phase CPU, while this only has 6 and 2 for VTT, why? have gigabyte just put more there for no reason? these boards do cost a lot of money, (atleast for me) and i dont want to make a choice i will regret, I have allways wanted a DFI board to play with, but on the other hand, dont want to make the wrong choice, will the less pwm make any diffrence? so for me it's ud5 or this board.. and 1 day to make my choice, i like to play alot, and do understand the most of a bios, like benches and stuff :)
Can't really say about the UD5 not had one. The 6phase dk though can perform as well as it's 8Phase DFI Lanparty UT X58-T3eH8 big brother.
Click pic for detail
4,410 21x210 DDR3 x6 1,260 6-6-6-16
http://www.images.clunk.org.uk/revie...@6-bench-s.png
with a 24/7 of
Ain't to shabby :shrug:
Anyone has good settings for QPI over 200MHz?
Hi Guys
Just got one of these and have couple of questions:
- why do you say that DK has Hybrid PWM - specs say "6+2+2 Phase PWM : 6 Phase for CPU, 2 Phase for VTT, 2 Phase for Memory : New Symphony ™ Pure Digital Power by CHiL" ?
- anyone put a waterblock on NB Heatpipe? If so, which one did you go for - did it fit without modding?
*** Looks like the best ones are EK S-MAX and Swiftech MCW-30 ***
anyone can help me how to enable turbo mode with this motherboard on windows 7, please need guide here
See Turbo Mode & the 2 posts following for more info.
i already tried to enable EIST but when it come to windows the multi become x12 even whne load, shoud i format my windows 7?
You should update to the latest Bios for your board, there are a bug for both the UT and DK board, that the latest bios will fix.
regards.
i already use the 2009-07-01 bios , is there any newer bios?
:mad: tHis MB is :banana::banana::banana::banana: !! cant even change multiplier on a Extreme 975 and iam stock at max 25 multis :( can just change down on multis to X 12 not over X 26 a range to 33 or more
and Dfi are very slow to update bios to
how about the highest fsb for this mobo fpr 24/7?
Did you change the Os powerplan as in :Quote:
Originally Posted by barong
http://www.images.clunk.org.uk/revie...apwropt-s.png# ?
That should fix ,multi to x21 as shown in the turbo mode link in my last post.
anyone try 2009-07-24 bios its said that
Major Reasons of Change:
The BIOS fixed Windows 7 CPU ratio issue
IT WORKS!!!
2009-07-24 bios
mine now is x21 :D :D :D
Nice one :) :up:Quote:
