Nanohead
The angle one are easy to plug into (HAF932 case ) heheheh .:up:
Nanohead
There's the GA-MA790FXT-UD5P (rev. 1.0) - their first 790FX/SB750 board AFAIK
and
a 790X/SB750 board called GA-MA790XT-UD4P (rev0 1.0)
both DDR3.
Hazzan, what RAM and vDIMM are you using there? 536MHz at 4-4-4-12 looks killer to me :up:
Cheers
Got one on the way :up:
waiting result to see if I should grab this or wait on the giga board...
Well the M4A79 DELUXE is here & there are quite a few diffrences bettween this & the M3A79-T if you look closely enough.
Installing vista right now... takes FOREVER.
Oh and ASUS still uses 30 year old bubble gum as "thermal interface material" on the chipsets. Took quite some time to clean off. And the whole heatpipe assembly is feather light. Probably not a single bit of copper.
afireinside you are back on AMD again I see :D.
I remember your AM2+ Athlon 64 tests back in the day,you had a fun time testing it back then :).
Good luck with your testing :up:
PS vista installation is the most boring process of all lol
The Vcore is rock solid, it just never moves at all.
Just ran OCCT had 0.00 ripple on all voltages except the ram with 0.02 ripple.
I would say that the bios needs maturing a bit as changing some things from Auto like CPU/NB vcore just makes it plain unstable.
Pity its going into a friends build because of PCI & PCIE slot arrangement & only seeing 4GB of my installed 8GB of ram & the loud popping power up sound going the through my Creative X-fi Pro.
Its a good board. Boot up with NB @ 3000
http://img443.imageshack.us/img443/5...shot058is2.jpg
Don't really care about stable or not, as long as it can finished benches.
Here 3Ds...
http://img231.imageshack.us/img231/8...shot049zj3.jpg
http://img231.imageshack.us/img231/1...shot051xu8.jpg
http://img511.imageshack.us/img511/2...shot050dl4.jpg
Lookin good Dumo! What cooling? Single stage phase?
Hmm... I generally have instability with CPU/NB volts other than stock. For instance if I change from "auto" to 1.4V now, my OC will go from stable to BSOD. HOWEVER, there was one combo with 2700mhz NB speed where increased voltage brought stability. I really don't know... What I do know is that I can't OC my NB worth crap. 2700 is as far as its gone :(Quote:
@ AFI, Its phase ss.
Try add more on NB/CPU and NB volts.
