nice 4811mhz 32M on i7 920!
That is some heavy clocks for i920 Solarfall.:up:
I can't even reach 229 bClk (stuck on 228 for now), kudos for running with max multi at insane speed ! :clap:
I have to make another Dryice Run.:shrug:
Nice clocks....and results also...
:clap:
i hope that once my new ram kit arrives im able to beat your score @ HWbot :D
pretty sure that there is some sort of setting combo that may allow me to clock that thing even more..lets hope i can find it
thanks mate i will keep pushing this thing even more.. next i will start to do some 3d benchmarking.. :D
alrighty time for an 3D update.. ran some quick benchies with my vmodded evga 9800 gtx card (water cooled).. i will run more 3D tests with couple of 260 gtx and do some vantage runs too for HW bot.
http://i163.photobucket.com/albums/t...otos/32100.jpg
http://i163.photobucket.com/albums/t...os/0619764.jpg
Is the bclk/QPI of the 920 going to be your limit? Will you try a 940 or 965?
Nice to see mine cascade helps to make good scores :p:.
Nice 3dmark06 cpu score of 8800+ :D
possibly when i get some more money :D
yeah good thing that when i ordered this beast from i requested that it would do around -100c with 300w load lowest that i've seen the temps go with this monster were around -99c wich is really good considering that i was stressing all the cores on my quad core cpu :up:
yep its not bad at all. :D
Solarfall did u solve problems with PWMs or RMAed board?
wow seems like quite a few 920's are getting insane speeds
seems like the one to get :)
seems like the pwm's on my board is toasted as in literately toasted lol its on its way back to the store where i got it from. lets hope the replacement board is better then the last one
yep these chips are fun to overclock but damn they run freaking HOT. too bad that the curent revision of chips dont scale too well with subzero cooling.
Nice i7 920 benching mate ! :up: and amazing board from DFI is can pushing bclk to high ;)
keep pushing it :D
Anyone tried going direct to 240-250+? Maybe its just a hole? :D
tried and no go heh
