I love your creativity!
The best part of this hobby is satisfying yourself. I applaud what you have accomplished and you should be very proud.:up:
Another sleever! I love it!!
We really need to have a sleevers forum.;)
Hey Jesse, your build is starting to look sweet! The clamps are awesome, shame my 6mm M3 screws are a tad too short to mount the clamps but once i've found 10mm screws my build will be full of them.
How's the leak in the rad? Did you fix it?
nice cable mgmt - the back of the m-board tray looks :up:
Installed my waterblock. I didn't feel like ordering a back plate for the price realistically they should just come with one but no matter. I installed ramsinks on the back. Ill see how my temps are.
http://img16.imageshack.us/img16/2346/gtx280003.jpg
http://img16.imageshack.us/img16/8585/gtx280002.jpg
Gorgeous pics!
You are better off with ram sinks than the backplate. I had one 280 mounted with one and the other off and there was no discernible temp difference.
Make sure you use real clamps with the Norprene tubing, It is MUCH stretchier than other vinyl tubing.
Been using it for 2 years now with worm drive clamps and never had to replace it.
Thanks Seeker, That is good to know makes me feel better about my choice.
@aspire, Yeah I just put the tube on to show how it will be. I used a thick zip tie on my test setup last time and it seemed quite good. I think it should be safe.
Finished today! but yeah Ill take better pictures tomorrow haha :p: I'm loving it though, everything worked out so well. It was allot of work and time but it paid off :D
http://img17.imageshack.us/img17/1861/lianli005.jpg
http://img9.imageshack.us/img9/6907/lianli003.jpg
http://img25.imageshack.us/img25/2931/benchb.jpg
http://img10.imageshack.us/img10/561...ifinish011.jpg
http://img9.imageshack.us/img9/4258/lianlifinish013.jpg
http://img13.imageshack.us/img13/768...ifinish028.jpg
http://img17.imageshack.us/img17/7119/lianli016.jpg
http://img10.imageshack.us/img10/2577/anotherlian.jpg
http://img6.imageshack.us/img6/627/lianlifinish018.jpg
http://img16.imageshack.us/img16/637...ifinish023.jpg
http://img25.imageshack.us/img25/132...ifinish026.jpg
http://img10.imageshack.us/img10/923...ifinish029.jpg
How I finished off the evening :D (Its actually Kilkenny)
http://img12.imageshack.us/img12/5265/beer002.jpg
That turned out good man! Congrats on finishing it and enjoy that beer! :toast:
great work and beautiful pics, well done:up:
Outstanding! A beautiful piece of work all around:up: You should be very proud of your efforts. Great pics too!
Turned out great.... love the LCD on the divider plate, you worked that in well and your CD rom coming out of the side of the case. :up:
Also do you mind me asking what kinda lighting you used?
This really came out well. I wasn't too sure about the neoprene tubing, but I like the finished look. It's different, but with a clean industrial look.
Also like your LCD display on the midplate.
You definitely deserved a cold one after such success!
Now this setup is a bit of me, keep the case door on get a stable OC and use the bugger. Enjoy dude it looks the nuts :D
Thanks Shazza, it was funny the neoprene tubing wasn't my first choice but I still wanted black so I tried it. Its got a really nice feel to it but its not the most flexible. Good thing I found out about bits power :p:
haha cheers Qman, so far Ive gotten over 18k in 3dmark06.
http://service.futuremark.com/compare?3dm06=10311530
Very nice, you fitted all of that in that case, I also love those V-series cases from lian li, especially wen liquid cooled !
Very nice build, you deserve a treat after all that hard work. Job well done. :clap: :clap:
