their pumps arent that bad, their tubing is good, as is their 355 tops. delta v3 cpu is a top performer at a fair price. it sounds like a great company to me.
Nice job skinnee :clap:
Thanks for testing my favorite sized rad first :up::rofl:
I'll have to see how many of my builds will actually fit these little beasts.:yepp:
Will this be the end for Thermochill? G1/4 thread, normal fan spacing and a decent paint job....hmmmm
top work mate - a lot of effort went into this and it shows!! :clap:
Keep it up :up:
...BUT...they have had QC issues in the past. If they can completely solve those, they will have a rather decent lineup.
Doubt it, there are still die hards out there that will use nothing but TC rads. Lets not forget, they still have the PA160 that no one else even makes. I'm waiting for DD or Jab-Tech to get some in stock so I can buy 2. If the rumors are true, I wish they'd hurry up and release the new rads already. :yepp:
Seriously. I'd but a RX480 right now if they made one. How disappointing.
The current selection of 4x120mm rads really leaves something to be desired. GTX480 needs too much CFM, TFC480 costs too much, Magicool...well...sucks, and I've not seen any solid data on the Koolance quad. An RX480 at ~$100-120 US would be perfect.
--Matt
:yepp: but, if they learn from their mistakes and make sure that it doesn't happen again and get people like skinnee to go over their products I don't see them having much problems in that department. I love the fact that others are getting in the high end gear which will help companies like Feser and TC to push their stuff harder and harder to get better performance and help keep prices down. Just my :2cents:
Do you mean the fin wasn't solid for the whole depth of the rad, but had slits in it? My MCR320 is like that.Quote:
One more thing on the topic of fins, the more I looked at the fins, something else seemed different. I tried capturing this in a photo but could not get the photo quality to really show what I saw ( I will keep trying though), the fins are split between the tubes. I have never noticed if this is the same on other radiators optimized for low speed fans. I will have to look closer next time I have a low speed fan optimized radiator in my hands.
Thanks for the kind words and feedback everyone, I truly appreciate the feedback and will try to incorporate it into further tests and reviews.
As Vapor said...it is a trendline and above or below the actual plotted data points are forecasts/predictions based on the data being plotted. It is probably close, but as to a confidence factor I could not say. I've been trying to find a way in Excel to calculate confidence factor like I can in other Statistical Analysis apps, but I have not found a method to do so yet.
Yeah, as I wrote in the Methodology/Specification section, Martin set the standard on the format and methods. Until I find something that doesn't work or could be improved, Martin's standard is the one I plan on following.
Paul mentioned that, I am trying to find out what exactly was tweaked.
The fins have small little slits in them, just the PA's and MCR's I have. But what I was trying to say (poorly I might add) was that for each tube there is a dedicated set of fins. There are three rows tubes for the depth of the rad and 3 rows of fins, one per row of tubes. The MCR series has a single row of tubes and the PA has two rows of tubes and I do not remember seeing two rows of fins for the PA. Does that help clarify? :shrug:
I'll try to get a pic that shows what I mean.
Great review thanks
With only 5 data points dictating a trendline with a (visually) low R^2 value, even the interpolative confidence level isn't great.
If you could get any data at low RPMs (400-500RPM), it'd probably go a long way toward contributing to the shape of the curve at low RPMs :D :up:
In this case, I think it's close (because the rad is designed for low airflow), but in situations where a radiator can be easily airflow starved....data at very low airflow levels goes a long way toward showing the shape of the curve :)
Again, great review skinnee :D
EDIT: is it just me or are the trendlines different on the various 10CdT graphs?
Well said! Yes, anytime you add data near or modify your spec limits that will start to change the regression/trendline.
Yes...nice catch. The single 10CdT is a Power trendline and the comparison is a 2nd order polynomial. The R^2 value is +/- 0.0007 between the two different regression/trendline types.
Insane rads for a super price :eek::eek:
http://www.tilatech.com/xspcrx120.html - 120
http://www.tilatech.com/xspcrx240.html - 240
http://www.tilatech.com/xspcrx360.html - 360
I think TC and Feser need to rethink their prices. :shocked:
Brilliant job, very informative. Great to see some reliable results for these new rads at last and they're worth waiting for! Thanks Skinnee
Maybe I missed it, but how does it compare to a TC? I have an old ass beat up PA120.3. Maybe the RX360 would be a good replacement?
Nice testing skinnee! I use XSPC kit and I think it's superb quality at a good price. I'm happy to see that you feel the same. Keep up the good work...:D
Good lord orgy review~ XSPC does the pricing right in responds to our economy while not losing it's performance. It pretty much RX360 I am expecting around 80 will be a great buy if the performance is scales right.
Great review skinee!
Looks like a great rad at a nice price point too.
