Stelaras has it too so guys please share!!!
or do they use Water-Cooling?
€: they use only Water cooling, no OVP mod
OVP mod is not needed anymore.
Use this instead.
Err??Quote:
max Voltage... 1350mV
There's no such max voltage.
People have gotten >1.6V via this soft VID mod.
Hardware OVP mod is not going to happen...
Well, you're going to launch RivaTuner anyways, and since you can schedule the command to be automatic when RT launches you don't have to manually do it every time.
i wanna know who has the cojones to buy this card and then try this out! what happens if it dosent work!??? :shocked:
It works ;)
Hello .
I tried this soft Vmod with my asus gtx295 and it works very well .:shocked: :up:
Before i could not pass 700 mhz gpu with defaut voltage ( 1.04 volt ) and now with 1.17 volt i can bench at 740 gpu !!
But i have got something strange : the voltage is the same at idle and load , even without vmod ! :confused:
So , do you noted the same thing with your gtx295 ?
don't know why, but card shows failures in 3D and freezes sometimes...
oh man that's no good
I have still yet to bench my card (this week sometime) and I will confirm this afterwards but.... From a couple posts it appears that OCP (which is what we are triggering with 1.3v here not OVP) it NOT disabled with the VT1165 softmod.
Unwinder says this:
Now one of the mods vince had done to his cards was "Power good" mod. I think this maybe the key to defeating the OCP on these?Quote:
Hmmm... That's a status of 100% healthy VT1165 VRM. The status bits include:
- VRM reports that its voltage output is enabled (VRM can be shut down due to fault condition on some of slave phase chips, e..g. due to critical overheating)
- VRM reports that output voltage is in "power good" state (i.e. the difference between nominal and real output voltage is inside pre-defined "power good" range, e.g. 100mV)
- VRM reports that there are no input undervoltage and overvoltage conditions
- VRM reports that thera are no output overcurrent and overvoltage protection conditions
According to these state bits, there is desired voltage on the VRM output. Looks like there is some other circuit on your PCB limiting the voltage behind VRM output.
little nice tool from my german collegues of Awardfabrik.de
Voltage Factory V1.0
http://rapidshare.com/files/19383349...dfabrik.de.rar
