You got a BloodRage Board? Nice!!! :toast:
Did the Netherlands office send it to you? :)
weird about the crash... ill see if i can reproduce it.
Are you using Vista 32 or 64?
What version of Aegis panel?
Btw, about SetFsb, im using version 2.1.69.2 and its the last ICS PLL on the list, which is ICS9LPRS919BKL and it works fine...
http://www13.plala.or.jp/setfsb/
the latest beta you can download from abos website is 2.1.89.0 and in the release notes on the same page he mentions that he added support for BloodRage with ICS9LPRS139AKLF.
I tried version 89 and it worked fine with AKLF at first, it wouldnt read any of the speeds correctly but i could increase the bclock. then i tried 919BKL and it actually read the bclock properly! which is surprising since it didnt do so in the older version. when i tried to set the speed with 919BKL it froze windows...
The weird thing is that i now tried again AKLF and 919BKL and both give me random errors... either setfsb crashes, or i get SMBUS error or i get PLL byte error etc... this was on vista 64.
So i recommend using the older version for now... or try the new version, maybe it works fine for you.
