That...is the first step to shilling....and shills are shot on sight. :frag:
...and honestly, you should be shot just for posting a link to that :banana::banana::banana:gy site in the first place. :p: (j/k)
First post updated with new spreadsheet, can someone who has a big monitor SS the spreadsheet, I'm on my laptop so I dont have enought resolution ;)
Had to zoom out a bit to get it the whole thing to fit on my 24", let me know if this is fine:
http://img187.imageshack.us/img187/8...ittingsnj0.jpg
Who said Bitspower 3/8" compression would fit the FuZion v1?? :mad:
Tried it this afternoon but it was a no go! I was going by this list so assumed it would fit but found out the hard way it wasn't to be.
Fortunately i had 1 Bitspower 45º angled piece so i could finish my loop but i had planned this 45º piece on top of my XSPC reservoir top.
Will redo my loop when i have a new 45º piece.
Please corrrect this in your list.
It depends on the OD Zeus. Which OD are you using? 1/2" or 5/8"
The chart has no data on 5/8" OD because it hadn't been confirmed.
Only 1/2 OD. 10mm/13mm. No fit, not even with the barbs touching each other, couldn't get the second one in when the first one was in, not even with brute force.
Did BP redesign their fittings maybe?
I will make an edit, thanks for the heads up, sorry we didn't get that right :(
I was just wondering if the Fuzion V1 fits these Bits Power fittings? :)
http://www.performance-pcs.com/catal...ducts_id=24267
I dont think so, the 5/8" OD 3/8 comps dont fit on the V1 so I dont think those will either.
yups, its confirm by my friend, 5/8 OD will not fit on V1 or V2, but don't know with the koolance one, coz they have a bit profile besides BP/feser/DD com fttings..
Do anyone know what I will be able to use with my Fuzion V1?
Is there not a single BP fitting I can use to get a clean and pretty seal over my 7/16" tubing from Masterkleer? :( :( :(
:cry:
I just got these from DD for use with my MasterKleer 7/16"ID 5/8" OD >>>>
http://www.sidewindercomputers.com/bi7cofifor5o.html
There is also black sparkle ones at Performance-PC's
Are you saying you do not think they will fit, or you just did not see them yet?
Plan to use them on a Aqua Computer Cuplex XT DI, seem to fit for sure but have not put them into use yet.
Why is there no 7/16" Listed in the first post? I came into this thread to check and add my findings about 7/16"
I will post my images/findings about the cuplex and 7/16" Fittings once I get it up and running tonight or tomorrow
if you want to use comps on a fuzion of any type just buy some 45 degree rotary adapters, they work great :up:
Then I will have buy some then. :)
The only problem is that they look a little bit big. =)
Ahh, Ok! Just wondered why no 7/16" had been added! I will post my findings for sure, for BP 7/16" fittings with MC-TDX and Cuplex XT Di
Someone correct me if I'm wrong (haven't had much sleep), but I assume the 7/16" ID x 5/8" OD compression fittings should fit whatever works with the 3/8" ID x 5/8" OD fittings ... since the outside diameter is the same...Quote:
Confirmed BP 7/16" Compressions Fit Aqua Computer Cuplex XT DI
Looked to be a bit tight on one of the acrylic threads bit sealed up no problems
I want to put some 45 degrees bitspower 1/2 (3/4) on a mcw-60 and a mcw-30. will its fits?
This is great info to have, thanks all
