1M:
http://i369.photobucket.com/albums/o...rWare/pi1m.jpg
32M:
http://i369.photobucket.com/albums/o...Ware/pi32m.jpg
x20/x36/x8/x16 4GHz no problem :D
http://i369.photobucket.com/albums/o...x36_x8_x16.jpg
Forgot to mention it was running at CL8-8-8 above.
Ready to break 10s Pi :D 3,999MHz
http://i369.photobucket.com/albums/o...re_1275vtt.jpg
looks ok to me
i like green and black look
those PCI slots stand out like dogs balls on both evga and XFX boards heheh
Sorry, haven't seen anything special here.
I managed to pull 217Blck on my Asus P6T Deluxe with just Watercooling:
http://img266.imageshack.us/img266/2...4531mhzdo5.jpg
Here is the Validation link:
http://valid.canardpc.com/show_oc.php?id=476622
That is a very nice 920 OC. What temps did you have? everything looks top draw, however with those setting I'm calculating 350w and temps 48C or so above ambient. You were able to get the 1333 memory to 1733 with just relaxing the clocks? Did you raise the voltage? Was this Prime95 stable?
What kinda wattage can the PWM handle? Also how many phases?
Yahh, that is a nice sets of clocks for a shabby retail i920 :D
That wasn't prime stable but I managed to pull about 3 Super 1M runs, as I was eagerly trying to brake the 9.000s barrier untill it crashed on me :mad:
But I manged to pull a steady run at 215x21.
Ran SuperPi 1m/8m/32m with the memory running at x8 multi resulting in DRAM 1720Mhz with timings running 8-8-8 18 1T, at 1.64 Dram voltage :yepp:
Those OCZ surpassed my expectations without a doubt, I just can't wait to see what they will do with 2v :)
They low timings of 7-7-7-18 1T run out at about 1650Mhz, again, at stock voltage, 1.64v.
If I want to go Above ~1700Mhz I relax the timings a bit to 8-8-8-18 1T or even 8-8-7-18 1T @ 1.64v.
BTW, here is a SS:
http://img91.imageshack.us/img91/499...988sxm2.th.jpg
hi vapour
clocking bus is no big deal
every board can do that on air as well
show us efficiency of the board
or really high loads with suzero cooling and lots of volts, show us some killer RAM OCs, timings, frequencies..etc
something that would excite XS members a lot more than trying to take a screen of 215/220 bckl heh :up:
well the nvidia SLI board of X58 looks like some kind of low-end mobo:down::down::down::down::down: the NB heatsink should've been like the 790i ultra, those are called sexy:eek:
but good work on OC :D
Yahh, your results are actually very good considering it is kind of a "budget" board (no offense here).
Air/Water is not really a difference when running 1 instance of SuperPi,
It differs when you run 8 threads if SuperPi or a Multi threaded app like 3DMARK or wPrime.
Dinos: we got a saying in my country: "god gives nuts to those who are teeth less" LOL.
