Thanks for your comments :) Base finished :up:
http://img140.imageshack.us/img140/4...0609gh5.th.jpg http://img12.imageshack.us/img12/827...0621bq6.th.jpg
Looks great :)
Dimensions?
Great pots BartX!
Works great for DICE so far. The temp pic is full load on my phenom II 940 at 4.5 GHZ using 1.7vcore
http://img17.imageshack.us/img17/6073/cimg1935qe2.jpg
http://img13.imageshack.us/img13/1035/cimg1937fw0.jpg
http://img90.imageshack.us/img90/4760/cimg1938mf4.jpg
http://img21.imageshack.us/img21/1629/cimg1959kg4.jpg
http://img13.imageshack.us/img13/7049/cimg1958vu2.jpg
http://img4.imageshack.us/img4/1015/cimg1957en9.jpg
Finished :) This set it going to one of XS users. Some specs:
- total height 180 mm
- base height 50 mm
- base/pipe diameter 60/54 mm
- weight 1200g
http://img11.imageshack.us/img11/9308/p1080657.th.jpg http://img11.imageshack.us/img11/8673/p1080661.th.jpg http://img520.imageshack.us/img520/266/p1080662.th.jpg http://img517.imageshack.us/img517/3516/p1080673.th.jpg http://img517.imageshack.us/img517/2879/p1080675.th.jpg
Has been great working on this with you bartx, I will definitely post performance numbers up as soon as it arrives.
To bad western union doesn't know how to spell :ROTF: would have made our lives easier.
If anyone is curious about the design I requested it this way and bartx made necessary changes based on his experience/knowledge.
My first pot after small modifcations ;) I made it about year ago, design isn't the best, but it's really cheap ;) Actually it's waiting for new owner :D Specs:
- total height 240 mm
- base thickness 12 mm
- diameter 54 mm
- base weight/total weight 250g/900g
http://img23.imageshack.us/img23/4988/p1080678.th.jpg http://img520.imageshack.us/img520/5563/p1080682.th.jpg http://img520.imageshack.us/img520/8175/p1080684.th.jpg http://img23.imageshack.us/img23/7285/p1080696.th.jpg
Nice design, it should perform quite well :)
Excellent work!
Gpu pot:
http://img204.imageshack.us/img204/3...0383nq2.th.jpg http://img204.imageshack.us/img204/6...0385ys7.th.jpg http://img407.imageshack.us/img407/2...0386yb0.th.jpg
http://img26.imageshack.us/img26/3306/p1090009r.th.jpg http://img26.imageshack.us/img26/9941/p1090012.th.jpg http://img26.imageshack.us/img26/7410/p1090016.th.jpg
Unfortunately it isn't SLI/CF compatibile but it's cheap and easy to insulate ;)
I have a idea for a somewhat universal gpu pot bartx.....If you want I can dissassemble it to show you my idea.
Just out of curiousity can you get 3" to 2 3/4" round stock?
Thinking of a no holds barred high mass LN2 cpu pot if this works as good as I think it will.
Another ln2 pot ;)
- base height 50 mm
- weight 1150g
http://img12.imageshack.us/img12/7034/p1090028.th.jpg http://img12.imageshack.us/img12/8274/p1090031.th.jpg http://img12.imageshack.us/img12/6813/p1090035.th.jpg
And two pics of all set, which is going to one of XS users :up:
http://img12.imageshack.us/img12/1076/p1090048.th.jpg http://img12.imageshack.us/img12/5966/p1090049.th.jpg
Good Temps;)
This pot was made some time ago, now I've got small break, but I'm thinking about new stuff. Stay tuned ;)
- base height 50 mm
- base/pipe weight 930g/1300g
http://img9.imageshack.us/img9/6294/p1090325.th.jpg http://img144.imageshack.us/img144/9641/p1090329.th.jpg http://img144.imageshack.us/img144/6372/p1090331.th.jpg http://img144.imageshack.us/img144/4476/p1090340.th.jpg http://img144.imageshack.us/img144/7787/p1090341.th.jpg
What a monster :rofl:
Lepiej wygląda jak nie ma skali ^.-
