Originally posted by bmg
Without the 4 pin connector all the +12V current is flowing through a single pin in the 20 pin connector. Assuming the processor power is generated from the +12V, you'll have problems unless you use the 4 pin. Any chance your power supply is causing the problem?
Possibly, though it was a tight fit. I will try it with another 480w PSU tomorrow to make sure, though I am sure I tested it with a multimeter on the lead and it was OK. It seems very stable at default but I can't imagine that will be good for overclocking as you say. Will have to experiment. Anyone have a good Abit contact to ask ?
