I still cant see how this can have such a huge advantage over the Supreme, which in every other test i've seen is literally within margin error of the likes of the GTZ, Fuzion V2 and Delta V3. :S
Yes the same Enzotech, but I used a different measuring method. At 1:56 hours of computing time that my test setup reaches after 30 mins. There is a temp peak at this point for about 2 minutes. Temps usually stay at peak during this period and I note down those temps instead of measuring a long time intervall that Martin uses. His method might be better and more accurate. I will do more tests using different methods to see what turns out to be more accurate in the end.
I only used a Black Ice Xtreme 240, so my deltas are way bigger than Martins. Between my best and worst block are almost 15C. The measurement margin lies within 0.5C, usually the results after several mounts only vary by 0.2C.
But as I said, I only tested 5 blocks in the latest review and had to use new tubing, so older test results might not be accurate. I did all tests with a D-Tek Fuzion V2 again which was slightly better than a EK Supreme in my previous tests. I am actually thinking about publishing my articles of the print magazine in some way or the other, but converting them is not an easy task.
That block looks to be a real contender. I can't wait to see some final numbers.
interesting results...how many mounts did you use? the sapphire better? have you tested it already?
I already said that in my earlier post. I use 3-5 mountings. In case the results vary more than 0.2C after 3 mounts, I mount them 2 more times or more, depending on the variation of the results.
Buy one then :p:
Read my post again. I am talking about a delta between water and core temperature, not idle to load. I originally used a dual radiator to have a common rad for a CPU only loop. For Nehalem, I will change the test equipment.
it seems a nice wb... :up:
no review yet?
Fr3ak, can you say if there's enough space to fit Bitspower 1/2" fittings on this block?
The distance from G1/4 hole to hole is 21 mm.
As for presentation of results: I am working for a print magazine and I hope you can understand that I cannot copy and paste the whole article. Otherwise nobody would buy the magazine with the result of losing my job sooner or later.
I pretty much gave you all information needed in the first post I made. To measure air and water temperature, I am using a standard temp probe that is connected to a Aqua Computer Aquaero and a external meter. I measured water temp in the reservoir.
Anyway, especially watercooling tests can vary a lot due to different test systems or mythology, so I can only advice you to read as many reviews as possible and form a conclusion for yourself.
Personally, I don't really care about every C in my 24/7 builds as long as they are powerful and very silent at the same time.
Maybe not enough space stock, but with the proper bitspower 45's you should have no problem.
Just another kick in the shins:
I have replaced my D-Tek Fuzion V2 with the Watercool Heatkiller 3.0 LT
http://www.abload.de/thumb/08.12.14166mediumnkne.jpg
The flow is lower (of course IŽd say), but the core-temps are better up to 3° on a Q9550 @3,84 GHz with several mounts of both ...
A real top product "Made in Germany" ;)
Bundymania did a nice review with an E6400 @1,45 V and if (like I have supposed) the D-Tek is almost as good as the Supreme, his results do correspond with mine (Q9550 @1,3 V) and almost with the results of Fr3ak (details not known):
http://www.forumdeluxx.de/forum/showthread.php?t=549569
I have used a few of the HK 3,0 blocks for i7 builds so far (CU versions), and am pretty impressed with the results. Mounting system is also top-notch, just be sure to buy the matching backplate for lga 1366 (it's not included :( )
I don't have any EK Supremes with 1366 mounting though so I couldn't do any comparisons between them. I really like how you can easily optimize the HK 3,0 for single-die and multi-die CPUs by inserting or removing a separation plate into the block :)
Curiously I had a (very) little bit better coretemps without this little plate - on a multi-die Q9550 :rolleyes:
Additonal information for users of bigger fittings: Watercool made a first revision of the HK 3.0 and increased the distance of the two connections from 20 to 21,5 mm (deliveries since last week).
