Originally Posted by
v0dka
In any case your problem is not because you now have watercooling, unless you have a leak or the mount is really bad.
You need to start eliminating causes. Try 2 sticks of RAM instead of 4, then try using your old videocard and disconnecting other non vital components.
Have you cleared the CMOS? You need to start clocking the system from scratch, 500fsb is quite the achievement. Try higher multi and lower fsb for the same speed. Also, 45nm chips do get worse over time with high VTT / vFSB. I even noticed this on my 65 quad, that would do 3.8Ghz 1.3v at first but then got a lot worse over time. This was with excellent watercooling.
Having a jiggawatt PSU doesnt mean anything, it can still have problems with that particular motherboard for example.
