and it still might blow out :rofl:
i like it :)
and you put a AC unit next to it :o
/me runs
Okay I subbed. Why? Because I have no clue what those sketches represent:rofl:
np: Haste The Day - The Oracle
LOL...
Fans should arrive today.
FedEx misseed my shippment. Basically to sum it up, its 2 fesser 480's sandwitched between 8 san aces.
So
Fesser - 25mm shroud - 38mm sanace - 38mm san ace - 25mm shroud - fesser
Thats the core. :P
thats going to be really fat, catch wait :up:
So you guys wanna see 8 stacked fans which cost more then some peoples entire H2O setup?
:rofl:
Core: Double stacked SanAces
http://i125.photobucket.com/albums/p...a/IMG_0113.jpg
Yeah its pretty thick.
http://i125.photobucket.com/albums/p...a/IMG_0112.jpg
Tomorrow i gut the other fans and makes shourds and attach it to the ends. More to come later on.
^^^^one step closer to that hovercraft you always wanted :rofl: great work so far man!
broke my soldering iron yesterday, and ran out of solder.
So i need to run to radio shack and pick up new ones.
how did you break the iron? ive yet to break one out of my like 5 :p:
quit messing with those cheap irons, get a weller. a 25 watt one is cheap and good enough for small quick jobs. i use a 60 watt most of the time, but since down graded to a 25 watt which i find to be perfect. :up:
i like your stack
finished splicing all the cables on my rads:
http://i125.photobucket.com/albums/p...a/IMG_0115.jpg
The core should look like this:
http://i125.photobucket.com/albums/p...a/IMG_0114.jpg
That's not a rad sandwich, it's a party sub! :rofl:
Dude that's insane, It would like freeze my whole main system ...
it look's nice anyway ;)
Dayum!
That's some beastly cooling right there!
man... this is wicked... never seen so much fans in one place before..... subscribed... looking forward for more updates
since you've gone this far...you ought to put the cold side of a few TEC's on one of the rads. that'd cool it down :rofl:
finally finished the core.
http://i125.photobucket.com/albums/p...a/IMG_0118.jpg
Very thick package:
http://i125.photobucket.com/albums/p...a/IMG_0116.jpg
http://i125.photobucket.com/albums/p...a/IMG_0117.jpg
Here im testing all the fans. :P
http://i125.photobucket.com/albums/p...a/IMG_0119.jpg
The tubing and pump assembly is whats scaring me.
i can feel air pressure more then 5ft away. :rofl:
Tommorrow i have fun with a lot of bitspower and koolance fittings.
:cool:
So that's 16 fans running off that sunbeam? (Any pumps or anything else plugged in there?)
HOLY SH*T! lol
Good Golly Ms. Molly, that rad sandwich is huge. Looking good.
30cm thick!:eek::eek::eek:
Now I REALLY want to see how that performs:up:
Sub'd. Rad sandwich. Splendid. :D:up:
Just in case no one's told you yet: You're crazy!
:D
wow how many fans???? ROFL, just a suggestion i wound recommend changing some of them fans for shrouds, install the Fan in an AIR BLOWING direction, not air sucking direction. shrouds do not work with fan installed in sucking mode.
shrouds keeps the air inside and improves the airflow through a radiator.
The air turbulence is increased within this tunnel volume and avoids the dead spot below the middle of the impeller.
just my thoughts :D
