very nice looking 03 & 06 (vantage is a given). cant wait till this goes 32nm :D
Congrats FUGGER!
You are benching alone on the 5G+ :D
good work once again, you really good a sweet chip compared to the ones seen so far
Elmor Bala did also say it rocks @ giga x58
keep pushing it Charles
Looking good Charles, thanks for both CF & SLI numbers :up:
Congrats Charles :D
Nice runs fugger. thanks for the compairisons.
You have one nice chip there, Charles.....you seem to be getting better clocks than almost anyone else I've seen so far.
Question....what is the cascade evap reading at full load?? -90c?
i want 01 results :(
Very nice scores. What do you think max clocks on DICE would be?
what´s the max bclk you´ve got with the UD5?
This chip is killer in Vantage :D Other scores are also nice, gratz :)
also 3d05 is pretty good for those clocks i would say 15 % more than with core 2 at same clocks which is surprising as generally 05 is more about higher cpu speed, to match fuggers scores in 3d05 you'd need a 6.1ghz plus e8600,, is the ddr3 used in the x58 standard ddr3 meaning running at normal volts as i see somewhere saying that 1.65 volt for ddr3 in this board
whats it like on aquamark fugger
i want to play
thanks for sharing
Nice 5GHz+ benchable at 1.55v. What are your thoughts about the Gigabyte UD5 board?
Good E8600s will pwn 3Ds still for some time, no matter what Nehalem are capable of ;)Quote:
Originally Posted by cowie
thats what i cant understand the very big increase per clock on fuggers 05 score compare to a dc but i'v seen shaminos ss at 5.0 on the i7 8300 cpu test points
here
http://d.imagehost.org/0189/4980.jpg
and on qx9650@5.0 same cpu test score 8300?
http://service.futuremark.com/compare?3dm06=8827837
hiya cowie maybe the slightly lower cpu score is down to fugger using an higher multiplier and lower fsb (qpi now) on the cpu also hes using windows server 2008 operating system so that might have something to do with it
It was the bios revision, fixed and shown in Hicookies thread where he ran 32m at a slower speed and beat me by a few seconds.
I will rerun
cheers fugger thanks
sry guys i must have lost you.
i ment that the i7 at 5.0 has same cpu score as Penryn at 5.0 in 06 but o5 is way improved?
i did not mean fugger's score was low
