i have 2 plug that came from new koolance DDC acrylic top, is it made from steel as well?,
I like my Koolance compression fittings because they work and they a decent price. $9 a pair they are pretty close to regular barbs in price. That isn't fanboism, that is fact. Just because people recommend a product for an application does not make them fans, even some Thermochill people recommend Swiftech's as an alternative based on price. Doesn't make them Swiftech fans, they just recognize there are always more than one choice.
i just noticed that my koolance 3/8 id comp fitting has steel part on the locking mechanism for the tubing, is it the same for 3/4 od?, i tested with magnet
is it ok to use?,coz i think this part will not make any contact with the coolant right?,
this is the part that made from steel
http://www.plikimage.com/images/0u275606.jpg
ROFLMAO..
That isnt even wetted, so why does that matter?
The only time you need to worry about mixing metals is if your water is touching it. That is a clamp that goes outside of your compression barbs to clamp it. It never touches water, so you dont need to be worry about it.
Rodney RMA'd those and we warrantied them no problem =).
In regards to the steel compression fitting. Generally, we only describe materials on the website that contact water. If we used brass compression fittings they would not survive being tightened with pliers (which many people though it is not necessary).
When R3 posted that pic the first time I post saying that the fittings probably got wet and the water with rusting debris from the outer ring covered the actual brass fitting, giving us the impression that the fitting is corroded.
I had the same results when mounting my koolance 3/8 on a RAD. I had them wet and after two days the outer ring started to show some rust. I just cleaned with some alchool and use WD40 to protect it. The fitting was perfect after some cleaning. Under normal use the fitting never get any rust.
