Hrmm, I think my chip just doesn't want to do 3.5ghz, either that or gtls need adjusting without core#1 being at a -5 offset.
vcore 1.41 (1.4 real)
vtt 1.35
PLL 1.58
SB 1.57
NB 1.67
NB step +3
CPU GTL 10,5,10,10
1:3 divider to take memory out of the equation.
At 438x8 (3.5ghz) I get a rounding or calc error in prime after about 2 mins every time.
I have tried:
vcore up to 1.43v
vtt 1.45
PL 1.62
NB step +4
All with no difference. if NB is less than 1.67 the machine bluescreens, but at 1.67 I get calc errors which makes me think that the NB is now stable but the cpu needs tweaking.
I have tried adjusting GTLs:
9,4,9,9
11,6,11,11
12,7,12,12
13,8,13,13
14,9,14,14
15,10,15,15
I think this is as far as I went, initially these changes made no difference but the last two caused the machine to hardlock almost instantly when running prime.
I am wondering if higher gtl settings are needed, but that I might need to also adjust something else to get it stable. In the past hardlocks have nearly always been related to vNB, i'm wondering if increases the cpu gtls like this means I also need to adjust NB GTL or lower vNB.
Failing that, what is a good methodology for adjusting individual GTLs? I'd rather have some kind of method than just random changes...
