Bingo !! More especially asking if it is a good idea to buy a aluminium part and mix with the copper/brass loop :rofl:
This watercooling kit, is what they use for the HP Blackbird, and upcoming Acer Predator.
To be honest, it doesn't upset me much at all.
This upsets me.
It's $207.
http://www.koolance.com/water-coolin...product_id=280
And it sucks.
Look at this great rad. Now look at what it's made of.
http://www.koolance.com/water-coolin...product_id=600
Congratulations, you just made me upset myself.
Out of curiosity, what's your beef with the first part? Aside from the price? You could probably do worse for a single 5 1/4" bay device that contains a reservoir, a DDC 3.2 pump, a fan controller, and temperature sensors.
From the Egg "Review":rofl:Quote:
This is a great product. I had it for about two months now and it had dropped my CPU temp dramatically. I have Pentium 4 3.2 GHz and the temp of it used to be 55C on idle and now its 36C if running on High then its around 33C. This is my first liquid cooling system and i couldn't be any more happier with it. Great product for great price. Deff Worth it!
LOL...I still have one of those in the Attic.. It was my first water cooling experience and to no suprise my old scythe infinity air cooler outpermed it even on my dual core. It was also a system a friend gave me because he didn't trust it. I don't blame him either, within a couple of months, the pump failed, cracked, and leaked and killed his brand new 8800gtx which had just come out at premium priced. He gave me the new RMA system that was given to him after his catastrophy.
Anyhow, I'd be leary after seeing what my buddy went through. If there's not much information about the actual pump/motor being used, who knows what you're getting or the risk involved..:shrug:
I'll have you guys covered in a few months. I'm developing a steel cored radiator with Al end caps. It'll go perfect with those finely machined copper blocks. :rofl:
Disclaimer:I am NOT serious.
This is probably the only All in one cooling kit that is any good.
And most here would probably agree.
http://www.newegg.com/Product/Produc...82E16835108105
Review of the single 120 version.
By all accounts it's no better that an Air cooler :D
http://uk.youtube.com/watch?v=GWlAPKFQeCk#
Im talking about the dual rad version.
It can be done and many have done it without too much concern. Just a question of adding the right anticorrosive agent in the right amounts and closely monitoring the loop. The corrosion can be adequately kept under control.....or at least this is what emerges from several posts around the forum. Performance degradation due to the additive is the tradeoff I guess.
You could but the metallic properties of copper and alu would mean that little if anything would happen to the copper blocks. Rather corrosion would spring a leak in the radiator. They would still be finely machined after some time.. :) If I am wrong please correct me.
Alex
Alexontherocks, I have a anti-flaming suit I can sell you for a special price...
i'll just hide behind the couch... hehe...
Upsetting XS LC section
1. Non-conductive coolants are GREAT! Look at my pretty fan bathing in it!
2. Look at my Koolance XXX! Ain't they pretty too?
3. UV DYES~~!
4. Mysterious growth in a loop, with the above 3 items being the prime suspects
5. GTZ vs V2 vs Supreme, each represented by fanboiz
6. Thermochill PA vs Feser TFC, represented by fanboiz, with guest appearance by Marci
7. Mysterious particles in a loop with a Thermochill rad, followed by a brisk exchange of cleaning methods that rapidly degenerates into pt no. 6
8. Thermaltake!!!!111!!!1 OMGWTFBBQ!!1111!!!!
Feel free to expand the list :)
9. Omg, So Blingy !!!
11. The air cooled gallery. All those people still on air cooling :( (Water cooled gallery pwnz!)
It reminds me of my first kit CoolerMaster Aquagate mini R80. It got my X2 temp down but the damded pump failed after 2 months.
Well itīs always good to start from somewhere and playing it safe if one doesnīt have the balls to build a wcing loop from the scratch.
12. Only noobs use plain water for watercooling. FluidXP+ is the best because it is non-conductive, unlike distilled water, which is conductive. FluidXP+ is also evironmentally friendly, and at $30 a bottle, it's so cheap! It's also anti-corrosion, so I can use as much aluminum and steel in my loop as I want. :sofa:
So you guys wanna play nasty huh with yah Aluminium and ThermalTake kits will take this then 80mm Aluminium rads on top of a copper block :D
Xigmatek AIO S80DP all in one watercooler.
http://www.techpowerup.com/reviews/Xigmatek/AIO_S80DP
http://www.techpowerup.com/reviews/X...installedb.jpg
http://www.techpowerup.com/reviews/X...ges/side2b.jpg
http://www.techpowerup.com/reviews/X...mages/topb.jpg
http://www.techpowerup.com/reviews/X...ges/side1b.jpg
http://www.techpowerup.com/reviews/X...mages/hsfb.jpg
Look at the size of that pump down the bottom in the middle :D
http://www.techpowerup.com/reviews/X...ges/pump2b.jpg
