Nice clock! I love your 13K Read!
Keep pushing, good luck!
Got 4 errors on the 4th loop at DDR3-1450 5-5-5-15 1T :(
Dropping down to DDR3-1420 now.
BenchZ
what are you getting on everest for 5-5-5-15 1T 1420 reading?
That depends quite a lot on the FSB used and the rest settings.
With Linked & Synched FSB/DRAM the Read BW should be around 10k and write/copy at 7k something.
With higher FSB and unlinked RAM it could be near 12.5k ( FSB > 500MHz ).
Currently @ loop 39, error-free :)
Bill, are you going to run tests on Intel chipset (X48-P45)???
I like these sticks^^
@dread77:
I'm gonna test them on various motherboards m8 before I review them.
Already gone through the Asus P5K3 Deluxe, Asus P5Q3 Deluxe, now testing on the Striker II Extreme and later on the P5E64 WS Evolution ( X48 Workstation board ) and maybe on a Rampage Extreme as well ( that depends on the golden lady a.k.a. Vivian ).
They seem to be fully stable at DDR3-1451 5-5-5-15 1T.
At 1450 Linked and Synched they'd error, but that's due to the Striker II Extreme so it seems, as at 1451 Linked & Synched everything is fine, memtest86+ test #5 35 loops error-free, and benching ok.
http://i37.tinypic.com/2cyrwxw.png
http://i34.tinypic.com/9734f6.jpg
http://i33.tinypic.com/339oh9c.jpg
last screen voltage ??
~2.23V
6-5-5-16 seems to be stable at DDR3-1600+... memtest86+ test #5 40 loops error-free easily but 1610, 1620, 1650, 1700 isn't working, probably it's the Striker II Extreme screwing ( bolts :p: ) around again.
Will have to re-check on other motherboards thoroughly.
you are not stable @ 1000 cas 7 with 2,23v ??
BenchZowner
Also stable in Win Memtest ?
Don't know about Win memtest ( I assume that you are talking about the Windows Memory Tester from HCI Design inc. ), but SuperPi 32M and some Linpack was ok.
The fact is that SuperPi and LinPack don`t load RAM as it Win Memtest does.
I passed 200 cycles in IntelBurnTest at 2,06Vdimm and had no errors. But I had 2-4 errors after MemTest testing. To get stable I had to increase Vdimm up to 2,14(actual).
MemTest 3.7 is the real killer of RAMs :D
Try to pass it mate.
e8600 q822
rampage extreme
CSX diablo 2x1gb D9GTR @ 1,96/97v
sapphire 4870
all@liquid cooling
mem tested with memtest 3.7
he is talking about this:
http://www.hwmania.org/forum/imageho...285d2690d6.jpg
Yah, I know that proggie ( http://hcidesign.com/memtest/ )
Currently memtesting at DDR3-1900 7-6-5-18 :D
thats right :)
post your result with relative voltage :=) GOOD LUCK AND HAVE FUN :)
Benchz
Whats the trick to achieve 100% stability with this sticks on the Striker II at high speed/tight latencies with 1T?
I always had to keep command rate on 2T to keep stability on nForce boards...
Hmmmm... DDR3-1900 7-6-5-18 1T :D
http://i34.tinypic.com/144ac88.jpg
http://i38.tinypic.com/35jmjgz.png
http://i37.tinypic.com/293ja6h.jpg
http://i34.tinypic.com/1zvd1tk.jpg
http://i38.tinypic.com/161i8g8.jpg
More to come....later on, or tomorrow :D
Do you think BIOS 1104 could help you to break that 13k barrier :D
Just fooling around before I go to bed :D
Sub-timings fully relaxed needed a quick 2GHz+ test :p:
http://valid.x86-secret.com/show_oc.php?id=425320
http://i36.tinypic.com/2hcgryg.png
http://i36.tinypic.com/2cqcie8.jpg
