bloomfield is sick in this chessprogram... 3.2ghz beat 4,4ghz. :p:
Look forward for your results..i think you just need 3.7Ghz - 3.8Ghz to take the first place!!
Opteron sux ballz. :( :dammit:
Here's my problem. I gave my word that I wouldn't post numbers or benches until the NDA is lifted and us old farts like to keep our word but I can say this;
Your going to have to push those numbers a lot because with just 2 hours playing I got them beat and I mean by a LOT!;)
I'm not saying that to brag but this thing is a beast!:yepp:
Thanks OBR...just a perfect screen:up:
Okay..here also my calculatings in a excel file about how many procent faster the Nehalem will be at same speeds!
my score at 3880MHz is on the way ... :up:
We have a new leader...like i have said and calculated..this is a great cpu!!
1) TogaII142JD-8cpu 21/45 02:17 130.670.694 7.599.623 +0,21 Nehalem @3.875Ghz(Core i7 965ES)DDR3: 9-8-8-24
Many thanks to OBR :up:
JP.
A big thanks to Rol-co:up: for his time and tests he do for me!! Just great:clap:
We see here very clear how fast the new core i7 is.
Just compare a Skulltrail @4.2Ghz and the core i7 965Ex @4.2Ghz!
1) TogaII142JD-8cpu 21/47 02:05 132.628.680 8.434.120 +0,25 Nehalem @4.2Ghz(Core i7 965ES) DDR3: 8-8-8-20 Rol-co
4) TogaII142JD-8cpu 21/46 03:46 208.317.723 7.345.841 +0,26 Skulltrail 2xQX9775 @4.2Ghz DDR2: 4-5-5-17
There is a difference from 1.088.279 nodes per second!! and that for a single cpu!
I know Rol-co will still tune his system to get more...:yepp:
JP.
Hmm..Until now I have only tried Bloomfield at 2,66GHz, but maybe there is more to it ....hehehe :D
wow, and i was seriously considering getting a kickass 5400 based rig instead of nehalem.
no longer.
Well, Monstru just run his core i7 920(ES) for me:up:...and asked him if it's possible to run @3.8Ghz!!
He gives me a very nice result,look!
3) TogaII142JD-8cpu 21/47 02:21 135.337.470 7.670.355 +0.20 Nehalem @3.85Ghz(Core i7 920ES) DDR3: 8-8-8-19 Monstru
5) TogaII142JD-8cpu 21/46 03:46 208.317.723 7.345.841 +0,26 Skulltrail 2xQX9775 @4.2Ghz DDR2: 4-5-5-17
This 920 beat easy a Skulltrail...:clap:
Thanks Monstru...but i think you can do better;)
List updated regular (first page)
Thank you Jean-Paul, I will try to do better, but now I have a whole bunch of tests to run. :)
Remember, we also have a 4-core Nehalem@4.2GHz beating an 8-core Nehalem@3.1GHz.Quote:
1) TogaII142JD-8cpu ... 8.434.120 ... Nehalem @4.2Ghz(Core i7 965ES)
4) TogaII142JD-8cpu ... 7.345.841 ... Skulltrail 2xQX9775 @4.2Ghz
This benchmark doesn't seem to scale so well with multiple cores. I wonder if/when there will be a Nehalem Skulltrail. Until then, it's not clear to me that non-overclockable Gainestowns will be better than overclockable Qx9775's.Quote:
7) TogaII141SE-16cpu ... 6.843.413 ... Gainestown 2xNehalem @3.07Ghz
Hi jt1..to my calculatings will a Gainestown or Nehalem Skulltrail at the same speed @4.2Ghz have +9.3Milj.Nodes/sec.
and that is much higher!
But i agree the scaling from TogaII is not so good as other chess engines i have! But still,if i use always the same engine for every system,it's equal for
test results i get..so it's very clear what system is faster!! The software i use is freeware but a top chess engine!
The result you take from 7) i get this at 8 August..at that time cpu and MB where in pre-test like ES!!
and it's a other TogaII version,because that time i didn't have a 16core version from TogaII142JD.
For the rest i use the same TogaII142JD from 2 till 16cores.
JP.
My result with 920 @ 4.1Ghz :) 20x206
Mem CL 9-9-9-24 1T @ 827Mhz 6GB.
CPU very hot :eek::eek::eek::eek::eek::eek::eek::up:
21/51 03:00 194.612.212 8.621.333 +0.32
Just great StrangerS:up:...perfect screen and you take the first place!!
6Gb memory helps alot,nice speed gain!!
Thank you very much for testing:clap:
JP.
hey JP .. :rolleyes:
21/44 01:52 122.655.156 8.747.857 +0,22 e2e4 e7e5 Ng1f3 Ng8f6 Nf3xe5 d7d6 Ne5f3 Nf6xe4 Qd1e2 Qd8e7 Nb1c3 Ne4xc3 d2xc3 Qe7xe2+ Bf1xe2 Nb8c6 Bc1f4 Bf8e7 Be2d3 00 00 Bc8g4 Ra1e1 Bg4xf3 g2xf3
:up:
Hey Rol-co...again take the first place:clap:
Today i get many results..so there is a nice update in my list!
Every time i get new results will be marked as "New" then you can follow more easy what is changed in my list.
A very big thanks to Rol-co (still busy testing :) ) for all his time and try to get out the max.:up:
Also many thanks to StrangerS he send me today 13 results!!:up:
And ofcourse thanks to all testers to help to make my nice list!!
JP...will continue...;)
