Codegen=about the worst quality psu's there are. I would dump that crap in a blink of an eye.
Thank your for explanation, but I will keep my PSU (for now I haven't got any problems, and it has nearly perfect voltages (2900 XT CF, 4870CF and Q6600@ 4300mhz or Pentium D- almost 400W at full load under SS,...) THe lovest voltage that I have measured was 11.98, so be carefull when talking about my super duper PSU:D
But we are not talking about my super duper PSU, but about Gainward GS 4870:up:
You know.. running that CPU stock really cripples that 4870x2. It doesn't have nowhere near enough throughput to meet the demands of the 4870x2.
My bad, misread :p: a CPU @ 2.4GHz is still going to pose a large bottleneck though.
You wont see a huge boost with the CPU @ 3GHz. HD cards only start to stretch their legs once you hit 3.5GHz+. My C2D @ 2GHz returns a score of 8k with one of my HD3k cards stock in 3Dmark06, going to 3.4GHz that score goes to 11k. Before anyone says it, 06 is NOT hugely CPU biased, its a 80\20 ratio. Anyway, in Crysis any FPS boost is a good boost, its not exactly a well optimised engine, it handles AA horribly wasting all kinds of untold memory, even with the supposed "fix" in one of the patches.
Lucky you ! Apparently they have fixed the problem now, but some people have had bad luck :(
Here is a link about it (sorry, it's in french) : http://www.generation-3d.com/SAV-Gai...it,ac12916.htm
Edit : seems the Palit 4870 Sonic (Gainward is a part of Palit since 2005) suffers from the same issue :
4870 Sonic review @ Hardware Canucks
My second Gainward HD4870 GS arrives in the next 2 days :D
:upset:
Still don't have it yet, oh well should be here tomorrow - it better be :(
Thats because the fan is not controlled with PWM unlike the main fan.
We bundle following fan controller with Palit Group HD 4870 series cards
http://www.elektroni.fi/tuotekuvat/G...PWM_SnapOn.jpg
When the smaller fan is running at 5V the card is dead silent.
The difference in card temperatures between fan running at 12V vs. 5V is only a couple celcius.
Hi all, i've this card to, and i test with the TRadē, but the hole dont correspond :'(
grrrrrr...
So how come nobody noticed they got that fan controller with there card?
Also It's not the core temp that's to worry about with your cooler, the small fan is there to cool the vrm's. Those are what end up burning up the card's.
I didn't get that either ?
Correct me if i'm wrong, but this seems to apply for a specific retailer in Finland which is this one if i refer to the pic :
http://www.elektroni.fi/?PHPSESSID=7...ch=4870+golden
Like everyone here, i had no fan controler in the box.
BTW this card's PCB is not following the reference design (1 cm shorter), so any cooler or full WB might be impossible to install.
I wrote to gainward about a cable, but no response. I have same controler like on pict, but didnt have 3 to 2 pin connector. i tryed to get in in varous computer and electronic shop (cable, or at least 2 pin connector like on card) but no luck...
Someone have any suggestion?
Thnx..
Nice :) it's a beast good temps you got there :)
