What's the weight of this beast?
problably weight of case + 50lbs im guessing
oldschool style, i like it!
1 kilogram = 2.20462262 pounds
20kg = 48.502 pounds
movie :P : http://pl.youtube.com/watch?v=kNdN2qgO1RI
What did you use to make the cuts in the metal and what gauge metal is holding up the compressor?
I always enjoy reading your builds. You make such pretty units.
@killermiller : I use 2.0mm zincked steel plate under compressor, and I use angle grinder and fret-saw to cut all . Mainly angle grinder with 125mm disc for inox cutting.
Thanks pur :cool:. Your "start" is not bad too :up:.
I forgot to mention that on move all fans were set on MAX speed that's why cooler is such loud there (unit have fan speed controller as I've already mentioned) . NL11F is noiseless compared to 120x38 mm Ultra Kazes on max speed :-O .
Regards
Thanks for all comments :)
Peter
