Latest EVEREST beta version implements GPU VRM current measurement for GeForce video cards,
improved and fixed GPU sensors handling on Radeon HD 4870 X2 cards
EVEREST Ultimate Edition v4.60.1509
If you purchase 4.6, will your license still work for all these updates? When does it get to the point where you need a new license?
Yes,even licence(pkey) from ver. 4.50 working for all versions.
Just copy (pkey) from previous folder and paste in new
So if I purchase 4.6, it would still work when updated to 4.7?
A purchased key is good for 12 months from date of purchase.
Ok, and then forever more when you purchase, you only have to purchase the reduced price upgrade?
Can someone verify my findings?! I downloaded the file above and it is INFECTED with the NewHeur_PE virus. :mad: Per the screen shot below I use NOD32.
http://img.photobucket.com/albums/v3...us_NewHeur.jpg
Please post your findings. If it is infected we need to disable the link ASAP!
Scanned with Kaspersky and found no virus. Also posted by Fiery.
Our software that you can download from our website is always virus-free. NOD32 may had a wrong signature in its database, that happens with anti-virus software -- although it never happened to NOD32 smile.gif
In the case you've downloaded EVEREST from another source, then please try to re-download it from our website.
Regards,
Fiery
Its false, happened to me today aswell with the same everest ive been using for days, there was something in the latest Nod32 update today that makes it think everest is a virus. It found all versions of everest.exe I had as a virus, and even newly downloaded ones.
So its either that its a Nod32 hiccup that should be fixed in a day or 2 via a new database update or everest itself is a virus, and its not the latter :P
all my versions are ones Fiery linked or official releases from the main page.
Whew...good to know! Zaskar the same thing is happening to me. I d/l'd the above file on my laptop. I ran a scan in safe mode on my Desktop and the Everest files I have used previously without incident were now "infected." Gotta say this is my first "FALSE" positive with NOD32.
Hopefully they will fix the error soon.
Thanks again!
avast found nothing, possibly false positive if you're using advanced heuristics
yea, I just had this today too. Quarantined it right off my drive and my flash drive.
Update for MSI K9N2 Diamond,
EVEREST Ultimate Edition v4.60.1512
How do you keep finding these updated versions?? They are not announced by everest and have a bunch of random characters on the file name to prevent guessing! And what is new in 1519?
003,
THIS is they forum site (search-->beta)
Fix bug save the report to file
Does the trial version not display VRM temps for the 4870?? before i buy the product i wanted to make sure it would read my sensors okay but i get nothing except mem, shader, and gpu temp. Am I missing something with how to enable VRM reading temps. BTW, Gpu-Z 0.2.8 is also not giving me VRM temps which i find odd since i have a 4870 (gpu-z, everest, ccc confirm that at least)
go go everest! :D
good to see they have full nehalem support now :toast:
i hope detailled memory timings are available too?
Is it alright to let go of RealTemp if I'm using this 4.60 version of Everest? I've heard some other folks say it's temperature readings are as good as RealTemp.
