how much more fsb ocs you guys getting from
stock NB
to
air cooled NB
to
Pelt/water cooled ?
stock NB
to
air cooled NB
to
Pelt/water cooled ?
well Creative's copy of MBM5 seem to have fixed the high cpu temp reported in mbm5 under load!
2.4C @ 2400mhz at 1.525v
testing with 2x Prime95 v23.7 instances max heat torture test
with my MBM5 5.3.4.0
cpu idle: -39C to -36C
cpu load: -8 to -4C (note i get same load temps even @3616 with 1.775v)
with Creative's MBM5 5.3.4.0 files
cpu idle: -39C to -38C
cpu load: -26C to -23C
i'm confused as i checked Creative's settings and the cpu temp setting sensor is same as mine :confused:
Now have to test to see if i get that abnorm +105C cpu temp reported heh
yay Creative's copy of MBM5 5.3.4.0 seem to have fixed the +105C cpu temp while running 2x prime95 v23.7 + super pi 16m - throughout the session cpu load temp was between -26C and -23C :)
Hmmm this is wierd bud...the other option would be to get another temp proggy maybe....sus out Sandra temps :)
Off to uni now so back later :thumbsup:
yeah it is weird...
well tried 303fsb/202mem and it booted into windows but the boot time was slow as hell - ran sandra mem benchies fine but slow loading the program - then when i went to run cpu benchmarks ATI drive reports device failure in the driver and windows reverts to 640x480 res @4k lol
http://www.fileshosts.com/pentium4/D...-1.7v/cpuz.jpg
http://www.fileshosts.com/pentium4/D...v/mem-buff.jpg
http://www.fileshosts.com/pentium4/D...mem-unbuff.jpg
http://www.fileshosts.com/pentium4/D.../aida-read.jpg
http://www.fileshosts.com/pentium4/D...aida-write.jpg
checked event viewer and saw
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 3/10/2003
Time: 12:17:11 PM
User: N/A
Computer: P4C800E
Description:
Error code c0000415, parameter1 e157a8a0, parameter2 00000000, parameter3 00000000, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 63 30 30 30 30 34 31 c000041
0020: 35 20 20 50 61 72 61 6d 5 Param
0028: 65 74 65 72 73 20 65 31 eters e1
0030: 35 37 61 38 61 30 2c 20 57a8a0,
0038: 30 30 30 30 30 30 30 30 00000000
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 30 30 30 30 00, 0000
0050: 30 30 30 30 0000
Event Type: Error
Event Source: ati2mtag
Event Category: None
Event ID: 108
Date: 3/10/2003
Time: 12:21:36 PM
User: N/A
Computer: P4C800E
Description:
The driver ati2dvag for the display device \Device\Video0 got stuck in an infinite loop. This usually indicates a problem with the device itself or with the device driver programming the hardware incorrectly. Please check with your hardware device vendor for any driver updates.
Data:
0000: 00 00 00 00 03 00 52 00 ......R.
0008: 00 00 00 00 6c 00 04 c0 ....l..À
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Event Type: Information
Event Source: Application Popup
Event ID: 26
Date: 3/10/2003
Time: 12:21:36 PM
User: N/A
Computer: P4C800E
Description:
Application popup: Windows - System Error : Microsoft Windows detected and recovered from a device failure. Please save your work and reboot to restore full functionality.
You guys are noticing major differences in OC just by the NB, I never thought it playd that big of a role with that new Max3 cooler on it... but mine does get very warm after about 30 minutes @ 275fsb 5:4... The swiffy MCX-159 is coming in a couple days, Ill let you know if it helps
just changed my pci slot fan over NB for a 80x25mm TT Smartfan2 75cfm fan and angled it towards the NB for better airflow
http://fileshosts.com/prometiaMach2/7c/mach2_009.JPG
You got some mad ghetto skills eva, I like the mounting action. :D
The MBM 5 thing has happened to me, insane temps until I deleted the config and reconfigured it, sometimes it picks up slightly wrong settings on installation, and that's not even taking into account the mad selection boxes and stuff it pops up during installation now.
If it ever happens again, just uninstall it and reinstall with a fresh config, works for me every time.
thanks.. i may need a few remounts of the evap to see if it changes things :)
Disabling ACPI and APIC may get rid of the infinite loop problem m8 - give it a whirl. Be best off doing a new windows install to match it.
Make sure ACPI 2.0 is disabled in bios too :).
PiLsY.
interesting will try and see... but wouldn't that lower 3dmark benching points some ? :)Quote:
PiLsY.
I didnt actually find an option for this in bios with the Asus...is it there eva?
ALso are you still getting the control panel losing focus after upping the agp/pci etc? Cos I stopped getting it after upping it :)
305+ needs my agp/pci to be at 36/72.....;)
yup there is ACPI/APIC in bios... can't remember where right now it's in the manual too ;)
3:2 divider allowed me to move past 293fsb 5:4 barrier to in memtest86 and 72/36 allowed me max i can boot into winxp stable is 301fsb at 3:2 without ATI control panel /driver crapping out on me
Just installed my APC UPS's software which is :cool: :thumbup:
my UPS as the pc + prommy mach2 connected to it and looks like i'm using 536W of power in this setup - lucky prommy doesn't use the PSU power!
http://www.fileshosts.com/pentium4/D...2-36/cpuz2.jpg
edit: after running prime a bit longer power consumption went from 476W to 536W ... which would give me only 9min on backup power - but i have an external battery on order to triple the capacity so 27-30mins of power @3600mhz with 536W :D
so means if Prommy Mach2 max power consumption is 200W
pc is using 536W - 200 = 336W of power :)
