So the way RRR has it is right then? (sorry it's late and i've drank far too much :) )
Probably, but you expect me to remember that far back...I have a hard enough time remembering what I ate for lunch today let alone that far back..:ROTF:
Seriously though, I'll have to check out your inlet right outlet left thing. If it works I'll let you know.
Anyhow, these pics explain it all best:
THIS IS THE CORRECT WAY ON A QUAD CORE
Thanks guys :up:
Much appreciated :)
You confirmed what i thought, thanks! You guys rock :up:
Wow, I thought I had my block oriented correctly. I changed it to the correct position based on RRR pics and got a 3-5 degree drop in temps. That was with me not even redoing my AS5, which I need to go ahead and do. This should be a sticky. Now the question is whether to lap my QX9650.............
Utnorris
http://i125.photobucket.com/albums/p...a/IMG_1143.jpg
:rofl:
norris, ive been telling my friends about that mounting style on the supreme. AS i said when the block first came out, i grabbed one, and then another, and then another.
I Even destroyed 1.
Minus the creators, and probably even them now, i think no one has more on hand hours on the supreme then i do.
It wasnt til reciently that people started listening to me because everyone had fusion envy while i moved on to better things. :rofl:
Another note, if you guys are gona make custom accelerators, you need to make sure the plate is = thickness to the stock. The reason why i say that is i snaped my custom plate in half trying to pry it off the block. If you taken off the block you'll understand what i mean about prying.
Oh wow... so for a dual core it's vertical? Will the supreme even fit on most mobo's vertically?
It's not that I don't think I will benefit from lapping mind you, it's just taking a $600+ processor to a piece of sandpaper that bothers me. In the end I will need to do it since I must have a really bad IHS. I am getting a 15c gap between my highest and lowest temps on my cores. I have remounted it a couple of times and still get the same or near same results, so I came to the conclusion my IHS was warped. Hopefully lapping it will fix it. Of course the other option is to see if Intel will replace it, doubt it since it is an OEM version. Anyway, again, thanks for the clarification on the orientation, thought I had it right based on the instructions included, but obviously I was wrong. :D
Utnorris
FYI,
I tried the right side inlet vs left side outlet and got worse temps again. For whatever reason mine is working best left side in, right side outlet. Why there is even a difference I don't understand. It might have something to do with the accelerator plates not being lapped flush and being slightly tilted. I was tempted to lap my nozzle plate, but I'm not doing anything until I get the "As Shipped" testing done.
I was suprised about the orientation differences as well, mine was really poor when the wrong way...about 4 degrees or so average core and the highest core was almost 7C worse. Differential between cores was also huge when wrong.
Try just flipping the nozzle plate and see what that does.
There is a little slag left behind from the lazer cutting and they are not cleaning the bottoms very thoroughly. This is apparent when you examine the seating of the plate when it's apart, the plate will actually rock back and forth a little bit. This could potentially be favoring flow on one side vs the other and it may not have anything to do with the actual top inlet location. Lapping the plate might take care of the difference is what I'm speculating..:shrug:
martin when you test my cuplex can you also rotate it 90 degree's and see if it makes any difference.
I hope you don't mean you lapping the block, wouldn't that take the bow out of it?
Utnorris
What mods besides lapping the accelerator plate are you guys doing to the Supreme.
Has there been any news of a different accelarator plate from Eddy?
Any chance we could get this sticky? For an easy find?
Thanks guys
