If the Goal is High Oc /High Volts with Phenom.
HONDA:yepp:thanx again,,
New my Everest was old:ROTF:
My max is below...Keep on top of your ASUS bioses..See if they have C1E setting. My new TA770 Bios did and it stabalized my power states..I can use 1.7volts now:shocked:
Keep it aroun 1.66v-1.68v .
@1.72 Mobo hates me when i do that.
KAZGIRL,, Phenom cooling suggestion..
Im running a single 655 pump with a Dtek fusion and two Bix3's with 86 cfm panaflows. These are two row rads with 1/2 tygon ..I use the Swifty mini res..
Little heads up on Tripple rads under a $100bucks for Nice cooling.
Swifty's for sub $60range and The Bix3's for arond $70 .Ive found that the Bix3's perform better on HIGH TDP heat disapation than the Swifty's with medeim to high flow fans. While using Low flow fans there about the same performance wise because MEDIUM to HIGH flow fans is what Thicker rads need like the BIX'3 and TFC.. Ive tried Both Swifty and Bix's and get More water flow with the Bix3's(due to two row circulation)..The Bix's Hold More water and are two row vs one row and will disapate heat better when the volts go up...
Swify 320 and 655 pum here( a smaller pump can be used but recomend the 655 for a single or two tripples CPU only loop).
http://www.swiftech.com/
Link to B'3 $66each
http://www.dangerden.com/store/produ...&cat=85&page=1
http://i168.photobucket.com/albums/u...ierra/bix3.jpg
Now New TFC'c that DD has,, they Rock.
The TFC 360Rad ..Special $99 bucks and performs like two tripple Swifty/Bix's..Im upgrading my Bixes to One of these for my CPU loop..Performs like the thermoChill120.3.
http://www.dangerden.com/store/produ...99&page=1#tabs
http://i168.photobucket.com/albums/u...sierra/tfc.jpg
Link where i get my Hose, pumps,tubing W/B's ,EK fittings and miscalaniouse stuff.
http://www.petrastechshop.com/watercooling.html..
My buddy just installed one with a Dtek and 655. It performs as good as my two Bix'3s because it flows twice as good and is almost twice as thick as the BIX3.
This will be the first $100rad ive ever decided to grab..The PA120.3 is $150 and this is very close to it flow and performanc wise i believe..
Ive used swifty's No dout there great budget Rads usually 50 each. I picked up two Bixs for 56each a while back on special. The reason i went to Bix was beacause the Swifty dindt cool as good with mediun to high fans and They are kinda thin compared B3's .Swiftys flow with one row of fins is identical compared to Two rows with Bix3 and TFC .
Swifty's and or Bix'3s are both great depending on what your planing on doing..Also depends on the room you have in your case or on it.My main thought is if your gonna go for a medium OC ,, go with Swifty's ,,but for HIGH TDP overclocking the Bix3. I will be getting the TFC once i find i nice new case for cheap..My friends Pc cools like mine with just ONE ,,but he is also running Intel:p:.
My Phenom 9950 @ 3.5ghz//NB2660+mhz = 1.66vcpu and 1.55vNB
Now this is verycool for NONCHILLED System and why i can Clock so good trust me.
http://i168.photobucket.com/albums/u...ighvoltage.jpg
