Very much so, I have a 1500W Space heater for cascade vacuuming. Helps a ton.Quote:
If He heats up the system with a hair drier as he evacs it. surely the low pressure inside, and external heat source will boil off most the moisture? Putting it on vacuum reduces the boiling point of water, if you can add heat from the outside, and lower the BP of water in the system enough. It should work right? If his needles are bouncing off the gauges lower limit, does he not have the required vacuum? Obviously adding external heat to the mix will also help
We gave you well dones haha, if your looking for a pat on the back you got it, we're just trying to make sure your system lasts, and you get it running to the best it can do :)
