LOL @ a wafer laying under the seat.
Thanks for the updates, guys :)
I can't comment on that but I was told by a VERY reputable source that those posted scores were very possible so I retracted.
If they "played" with the engine then they know but I don't.
All I know is that 45,000+ In Cinebench10 is huge.
A dual socket 8 core Harpertown at 4000mhz is app 30,000 in that benchmark for example.
I can confirm the score of 45850, Cinebench info says:
Intel(R) CPU 000 @ 3,2 GHz
8 x
Windows 32 BIT 6.0.600
ATI Radeon HD 4870 X2
But there is a sticker in front of system which says: "Nehalem overclocking". They had a system on display, normal case, normal aircooling.. nothing special..
Movieman,JC already shown us the Bloomfield 2.93Ghz numbers for 32bit Cinebench(see the quote below).There is no way in hell that score was done with regular Cinebench 10.
From what i see (Sampsa's post) it indeed was a single socket SMT enabled Bloomfield 3.2Ghz chip,although overclocked and running 32bit OS and tested with modded Cinebech10.
User Boschwanza already explained that 45K result several times...
http://www.xtremesystems.org/forums/...0&postcount=20
With regular Cinebench10(unmodded with Cinema11 core), you can't jump from 17K(or 20K with 4ghz clock for Nehalem) to 40+K no matter how you look at it... From the exact 45850 figure,you can even calculate the OC speed of that 3.2Ghz Nehalem chip.It was OCed approx. ~1.2-1.25x,which gives us 3.84-4Ghz range (4850/ (17K x 2.2) ).I used the ~2.2x speedup for modded Cinebench since it varies a lot on different systems.Quote:
Originally Posted by Boschwanza
I understand but I want to hear the answer to my question from Sampsa as he was there and saw the machine.
I don't doubt what JC said but his was a prerelease board on single channell memory and a beta bios.
I am assuming that the machine shown by Intel yesterday could be a little "better" for lack of a better word.
Hmm,i thought JC showed(near the end of his preview) the completely functional 3 channel Bloomfield system.The numbers from that system were even used by Hornet to make one of his charts for comparison with K10 and C2Q if i'm not mistaken.
What i said in my previous post is only based on logic.No 3 channel/better tuned system can produce 2x the score,it is simply against logic(and what we know from uarch. evolution-Nehalem is the same 4 issue 128bit SSE/fpu capable core).
I'm hesitant to say anything here since I will probably come across as clueless, but hasn't it been an issue in the past regarding benchmarking software that some programs were optimized for the Intel micro-architecture and instruction set? Maybe the new incarnation of cinebench is an instance of that. However even in that case it's hard to see how you would get 2x the score so I see Informal's point.
But this might be a good thing for Agena and Shanghai. Anything optimized for Nehalem will probably also favor AMD's chips due to similarities in the architectures. Does that make sense or am I completely clueless?
I've been thinking the same thing, there are enough similarities among k10.5 and i7 that anything optimised for one will be good for the other. Thing is k10.5 is stuck with a 3 issue core unlike nehalem/conroe's 4 issue core, my bet is that is what is killing performance, not the l3 cache. But enough of shanghai, we'll know soon enough if amd sinks or floats due to shanghai
Uhmm...no? They are massively different.
You want to read this:
http://www.realworldtech.com/page.cf...0208182719&p=1
http://www.anandtech.com/cpuchipsets...spx?i=3382&p=1
So you provided two different articles covering only one part of the question and claim they are absolutely different. Well from my understanding you either claiming that nehalem is absolutely different from nehalem (hope you not THAT insane) or your comment has no base.
I haven't read the articles yet, but I will.
What I had in mind was the change from a massive L2 to a small L2 + shared L3. That's a standard design feature for AMD. IIRC, there are certain benchmarks that can reside happily in a large L2 and give an advantage to chips using one.
Try stay on focus for once. And compare Nehalem to K10. They might look the same with 3 issue and L3 cache etc. But its day and night in difference.
And I provided 2 articles since I assume he knows about K10(.5)
Mod trolling? And personal attacks since you consider me insane on a certain degree?
Put's on scratchy mod hat..
How about everyone take a breath in here and calm down..
Thanks..
I'm calm. Who says I'm not calm? HUH? WHO? WHO THE :banana::banana::banana::banana: says I'm not calm?
I'll show you calm. I'm more calm than any of you will ever be!!!
DO YOU HEAR ME DAMMIT!?!?!?!?!
http://i105.photobucket.com/albums/m...k/notAngry.jpg
*imitates yelping of scared wiener dog and runs away* :)
charles were those temps you posted idle temps? or did you have something running in the background?
i assumed idle because the cooling wasnt engineered for the new quad's. or... ????
Damn FUGGER what brand of notebook were you using, sounds pretty badass.
Yes, normal desktop PC with single socket and HT on. AFAIK it was Core i7 Extreme Edition 3,2 GHz overclocked to ~3,6 GHz. On display it had Cinebench R10 open with the +45k result.
PS. Here is a pic of me and my buddy in IDF :D
http://plaza.fi/s/f/editor/images/0821idf01.jpg
You mean the one sitting down drinking the bottle of water .... Sampsa' attention seems more focused on the other person... I am beginning to wonder about his priorities :)
BTW -- WTF is a hot babe like that doing at a geek fest -- is she into computers? What a nerd dream girl.
