you can edit the file DFC.INI and you can use less than 50%.
the cach is if you make any change (open the program and click save) it will go to 50%.
the solution will be to put the modified DFC.INI in another folder and start the program whit a bat file that first copy the file and then start the program.
I use 35% almost no noise and idle at 55.
