So will a fix for this definitely require a new bios?
Just that i'm still finding settings on G28 - will G29 be the same except for the 4870X2 fix?
nooooooooooooooooooo
i try g29 same problem:confused:
Running 4.275GHz @1.5 vcore on P5E3 Prem. (450x9.5 qx9650) I checked again and my UPS shows up to 955 watts when running 3DM06 on the next to last graphics test. Vantage averaged higher with extended periods of 935+. The card fans spin up real fast to let you know when you hit peak loads. This is an open test stand with a 3 fan rad. and 3 other fans plus a physx card. It was not easy to get cfx to run on this board. There is no display until after post is complete and you get to the windows sign in screen so bios are not available with this 2 card set-up. I hope to get my BlackOps running in cfx with the G29 bios that LardArse posted. I use a TT 1.2 kw psu for these boards and obviously it is needed. By the way, two of these cards run wicked with the games I've tried including Crysis.:D
I will post results of G29 on BlackOps later tonight.
I can confirm spl's findings. CrossfireX does not function with G29 bios on BlackOps. The board will not boot with the CF bridge attached or not. :(
Right, I'll wait for another to do CrossFX tests
It works on my p5e3 prem but not the way it should. Like I said it was difficult to get it started with several hard re-boots and using the keyboard with no display. There is NO display until the Vista password log-on screen so the bios are NOT accessable. I could not find a way to get into the bios with both cards attached but the system ran smoothly when in Windows.:shrug:
news???
I read that other motherboards required a bios update to get these cards to run, specifically some DFI ones.
Good to know it's not an exclusive blackops problem, i guess.
So how about that bios guys :)
this worked good for me fixed the xfirex 4870 issue:
http://www.yourfilehost.com/media.ph...e=7A3F1G30.rar
pls let me know...
Wow, thank you. :up:
Maybe we can try this at Games Convention next weekend. :D
I will test tonight.:up:
Yep. Works as advertised. Normal boot w/2 4870x2 in cfx. Thanks for the quick response!:up:
