Originally Posted by
phelan1777
You can step-up if your card qualifies, in that you won't know for sure till you register your card on in EVGA's site and it will tell you if you are able to step up.
Ie GX2 to 280.
If you buy a GX2 on fleabay and not from a reseller (which there are limited ones EVGA supports) then you not only will lose warranty but also the ability to step up as well.
My .02 I own a GX2 as well as an 8800 Ultra. I was getting stuttering with the GX2, installed the Ultra even though an older card, get better FPS and no stuttering..........I am happy for now.
Debating moving to a 260 as well.
