Originally Posted by
cablesguy
u just hv to keep at it until it clears, i used up more than 45ltrs of distilled in the process,
I think this is Rankers advice, sorry if its not:
"1) Buy 10 gallons of distilled water (how much is that in ltrs?, anyways i used up 50++ ltrs)
2) Fill radiator up with boiling DI water, cap, shake for 2 minutes (great forearm workout!) empty. Repeat 3-4 times.
3) Fill same radiator with boiling DI water again. This time, cap it off and leave it sitting for 3-4 days.
4) 3-4 days later, boil more water, and soak all of your waterblocks in the boiling water. Use tongs to handle your components or wear gloves to not leave oils or what not on your blocks.
5) Dry all of your blocks using coffee pads or your woman's make-up pads and rest them on something lint free.
6) Open up your radiator(s) that's been sitting and pour out contents. You'll notice milky stuff come out. Now flush 2-3 times again with room temperature DI water.
7) Pour boiling water down your tubes.
Now you're good to go with the installation process =)"
Heres a pic I took during cleaning
