when i instaled it looked exactly like above, except no ACC options, they where grayed out,
did you fully uninstal the last version of AOD before instaling 2.1.2.?
New board, same CPU:
9850BE
JAAFB AA 0809APMW
3.2ghz
1.35v
Gigabyte MA790GP-DS4H -790GX/SB750
http://valid.x86-secret.com/show_oc.php?id=400966
h2O
OS - XP x32
i got this today.A brand new 9850.Pretty strange stepping/batch don't you think?
Attachment 83591
Quite recent! Post results :)
Good chart. I'm also glad to see it updated more frequently now. I will suggest to you what I suggested to the last maintainer: Try saving the image as a PNG. File size for this type of image should be similar and it will also not have any compression artifacts since PNG is lossless. :)
hey i will take that PNG suggestion and try it out matey thanks :up:
yeah it will be updated nearly as soon as results are posted,
at the moment i have put of riverricers result for a couple of days to see if any more come in by the end of the wekkend, then i will update.
so next update, sunday say, as i am going on Holiday :D
and i wont be back for 2 weeks, so dont panic :shocked: results will be updated when i get back, and i havent disapeared to the 'ex-XS-posters graveyeard'
so if you want to be on the chart in the next two weeks, get the result in for sunday and i will update it :up:
I am planning on removing my system board heat pipes next week and replacing the entire thermal compound with OCZ freeze to see if this will lower my system temps. I have already used OCZ freeze on my CPU cooler and found it much better than AS5. Once I have done this I will try for a higher clock. I am doing this for now as I have never been happy with this board or Asus. I can not wait until the SB750 boards come out in the UK so I can get rid of the board I have. If any one has any tips on clocking the Asus M2N32-SLI Delux board they are more than welcome to give them to me or know any one selling SB750 boards in the UK then please give me the INFO. So with any luck when you get back in two weeks I should have a better clock for you to add to the table. I hope you have a good two weeks away. Enjoy yourself.
I want to see that 9850//0826 BPQW clocked:D
I have my eye looking at another 9950 soon.
Nuts24,,
From what ive seen with the M2N32deluxe it does like the (CPU to NB )set @ 1.3v-1.35.. Helps with Ram to IMC stability while using high freqency and lower timing coupled with phenom. Ganged and unganged is pretty stable for most rams @ 400 through 1066 on auto timing. I prefer to use (High freqency) with all other ram settings ive used..
Note: 5-6-6-18 2t is pretty optimal if you choose to raise FSB for higher Ram freqency..
SLI ram set to (High Freqency) and (MAX OC)
Also Disable,,
Virtualizatin,,TLB fix,,AMD live and any spread spectrum..
Chipset is set to..
MCP HT speed = 5x
MCPHT width = 16 and 16
SB HT speed =5x
SB HT width = 16 and 16
If using NVIDIA graphics set GPU ex to Auto.
If raising the FSB/HT above 220 lower MCP HT to 4x..Even though the Mobo can do 3000+HT with a X2 , The X4 Phen is a little different
The NB freqency will raise when you raise the FSB 201+ around 220 = 2200nb and FSB..240 = 2400nb .If you set the CPU VID or Vcore above 1.3v it sets the same for the Vcore and NBvolts on chip...So if you raise the FSB make shure you up the CPUvcore alittle for the Added NB freqency.:up:
Higher on chip NB freqency will add a 1-4c to your current temps depending on the cooling...
could you update mine? its 24/7 stable
http://img.techpowerup.org/080815/Ca...6-20080815.jpg
its under custom water
MSI K9A2 plat v1<-mosfets cooled by 120mm fan
Phenom 9500 CAAZB AA 0745 GPIW @2838mhz 1.42v
XP32
Some update, of course not really stable ;) :
http://www.abload.de/image.php?img=unbenanntbsi.jpg
Oese / 9750 JAAFB AA 0810GPAW / 3,536ghz / 1,552v / Cpu-z / DFI 790FX-M2R / Win XP 32bit / Water
Perhaps you might add complete stepping and 3h Prime to my 3,2ghz Vista 64 record as well?
http://www.xtremesystems.org/forums/...1&d=1216910616
Thanks for the tips gOtVoltage. I will give them ago when I have done fixing my board.
hi soundood, updated entry here... :D
Model: Phenom X4 9550
Batch: JAAFB AA 0810 GPAW
Frequency: 2805MHz
Vcore: 1.375v (Bios set)
Motherboard/chipset: Abit AX770/SB600
Cpuid validation url: http://valid.x86-secret.com/show_oc.php?id=404211
Cooling: Air/h2o/xtreme: Air (PC Cooler HP-1204)
http://img367.imageshack.us/img367/9...2805kf8.th.jpg
http://valid.x86-secret.com/cache/banner/404211.png
If I make a program for you that makes it to where you can edit the table in and have it publish it automatically as an image online, would you use it? (eg, you open it up and edit the table, then click a button that both saves the table and updates the online image--no further action required to make it update here)
HI there,
i was under the impression that the same CPU gets one entry, ie the highest, regardless of OS, this way there is no confusion, only way a CPU gets two mentions is with a new MObo
the SB750 to be honest, ill update scores to any cpu, but in the order of orderness...this is the only way this can work,
is it a new CPU?, have i misunderstood?
let me know Oese, no prob if it is,
but i am right in thinking this ehhh? after all i dont make rules, we all do, and if you want to include multiple results from one cpu, then fine, but i think it will end up a mess and very confusing :confused:
ok guys all updated
i am going on Hols tonite :up: and i will be back on the 28th, so no more updates till then, keep them posted but, and i will fire through the updates when i get back :yepp:
nice ;) :up:
everything's okay.. same cpu so all right. just thought different os' results would be interesting as well and didnt know the rules for sure.. my fault..
now, guys, come on with those 750sb-acc-devils do some shots for max oc :up:
as i said matey, we all make the rules, this is an open thread here and any suggestion will be put before us all for vote.
i just think, if we all agree to this, that we need suggestions as to the format of the layout.
and in itself might become to complex for one single sheet?
discuss, and i will be back on the 28th, to implement any agreed suggestions :up:
I dont know if the issue 32 vs. 64bit is worth a whole new list.. perhaps someone else has some opinion about this?
Any setting that can impact overclocks by 100-200 MHz or more deserves a column I think.
but it must be clear if it is the same cpu or another. otherwise it could just be a better/worse overclocking processor of the same batch.. what would be interesting as well with regards to variabilities in one batch..
whole processor number is a little too much i think?
So, first early attempt ..I installed it to my dfi, booted just fine at 200x15 with default vcore.So far so good..9850BE 0826 BPQW.Stable Spi and 3d..Of course more to come!
Attachment 83836
Is that Vcore correct if so ,Oh thats a sweet chip...
The Volts are priceless:up:
I seen A BUNCH of 0816- 0820 batches that dint like to work good @ 3.0ghz+ with below stock volts this is very,, very good...Especially take into consideration that the average Volts for 3.0-3.3ghz ive seen has been around 1.35v-1.45v Air/decent cooler with 9750 and up Phenoms:yepp:
Killer chip there DevilCry & may get 4GHz out of it on a 750SB mobo :D
Spoke with him....
Can't go anywhere higher stable with default....
3.2 and more are easily attainable with 1.35+ but not stable....
Thing is he ain't got any clue on phenom o.cing......
He promised max mhz with at least 1.5volts... So waiting :D
