AFAIK, only Koolance 3/8" compressions fit the FuZioN's and most of the other closely spaced fittings blocks.
These are with the older v1 but the v2 has another 1-2mm between fittings IIRC.
http://www.xtremesystems.org/forums/...9&d=1207291094
http://www.xtremesystems.org/forums/...0&d=1207291094
Okay time to find where I can get some of these in the UK... Price is incredibly restrictive though :/ So far I seem to find them at £5 for a single nozzle... :/
Edit: Meh, looks like FrozenCPU is gonna be the cheapest option, and that's including shipping to the UK XD
Really? It doesn't seem so awfull :
http://www.koolance.com/water-coolin...nzl-dxg_p0.jpg
OK guys. Thank you for advices! I forget about those.
Since the Apogee GTZ is coming, maybe i could get rid of Fuzion 2. I hope Swiftech is back!
XSPC Edge would be another good alternative but why the heck using Acrilic?§
Another tip : Tygon 3603 7/16ID 5/8OD is compatible with the Koolance 1/2 Compression fittings, but pretty hard to tighten.
That's because it's the wrong size. Comps should only be used with the proper sized tubing. If a fitting is rated for 1/2" x 5/8" tubing that means the fittings will only work properly with a tube that has a 1/16" think wall. If you go and use a tubing with a thicker wall tube, it will pinch in the wrong spot, possibly cutting your tubing and lead to a very unfortunate mess and a well deserved lesson.
WOW!
There's no need to be such dogmatic!
Tygon 7/16ID is my favourite tubing, and I won't change it.
Comp Fittings are sexy and I wanted to have a try.
What i can tell is it fits pretty well despite it's not made in this purpose.
The hardest part is un-tightening! And after that, tubing don't show any cut.
I think the issue isn't with thread patterns but with the size of the barbs and the clearance between the intake and outtake which are too close together to fit them.
Got an email from watercoolinguk.com that the Edge is being tweaked at least to replace the acrylic with acetal. That other XSPC block (X20 V2) looks kinda interesting too.
Edit: Feser has some 1/2" x 3/4" comp fittings in production but, according to a reply I got on the feser forum, nobody in N.A. has picked 'em up yet. (?!)
Edit: @ RRR - thanks for the heads' up on the Sidewinder bitspowers. Actually $2.45 cheaper a piece, $6 less for a pair.:up:
