Originally Posted by
saaya
there is ZERO difference in running memory with a quad or with a dualcore cpu... zero :D
the only difference is that you have a much harder time to reach high fsb speds with a quad compared to a dualcore, and youll never reach the same fsb with a quad as with a dualcore.
to check if your problem is cpu or fsb related, use the 6x cpu multiplier and check how high you can get the fsb with the 1:2 memory divider
if you cant get a high fsb, then your cpu limited and need to work on that before you can reach high memory clocks. the most important thing is vcore, then vtt, then comes pll voltage, nb voltage and cpu gtl settings.
