Okay...deadspots...been meaning to go into more indepth than I have in the past. (
1,
2,
3a,
3b,
3c).
Here's a few minutes work with a bit more detail....but it's still all 'worst case scenario' (that doesn't actually happen since the airflow diffuses and evens out when the fan is separated from the fins even a little).
Below are the three images I made and used in Photoshop's analysis tool to measure the area of the blue sections.
The green lines are used to separate the 12 channels of airflow a PA series radiator has (has 11 waterflow channels (IIRC) that act as partitions to the airflow).
40mm deadspot:
http://img363.imageshack.us/img363/1...eadspotfz2.png
50mm deadspot:
http://img383.imageshack.us/img383/3...eadspotzm0.png
60mm deadspot:
http://img354.imageshack.us/img354/9...eadspotky1.png
No deadspot:
http://img385.imageshack.us/img385/5...eadspotpq2.png
Graph plotting the percentages of airflow through the 12 channels. None are all that far from 'ideal' (and this is worst case scenario).
http://img257.imageshack.us/img257/3...cture46dy3.png
EDIT: because the graph isn't 100% clear...I'll put some numbers behind it.
Here's a listing of what % of airflow the center half of the radiator gets (outer quarters are 100% - whatever I list).
40mm deadspot: 54.86%
50mm deadspot: 51.56%
60mm deadspot: 46.79%
No deadspot: 59.74%
Ideal: 50%
Here's a listing of what % of airflow the center third of the radiator gets (outer thirds are 100 - whatever I list).
40mm deadspot: 33.46%
50mm deadspot: 30.79%
60mm deadspot: 28.79%
No deadspot: 40.72%
Ideal: 33.33%
Note, again, these are worst case scenarios...real-life distribution of airflow tends away from listed and toward ideal.
