Sounds like you have the wrong .inf file? I have vista x64, so I don't know about vista 32. After it installs (177.35) does it say no changes were made? If that's thats what happens, you have the wrong .inf file.
-q6600 @ 3.6ghz
-8800gts g92 512 OC'd
-Vista Ultimate 64
-175.16, updated 177.35 w/ modded .inf :up:
-Stock (650/1625/972), OC'd (784/1960/1013)
-5644.8 ppd
will it work on vista 64 with the 175.16 driver? Im to lazy to try new drivers..i like the 175.16's for my games.
it seems to be working, but entering team number for XS does not show up in the Viewer..says Team:running now
donor: core is not
what gives here?
it is going through the WU though, fairly quickly on my 8800GTS
It's telling you it's not running, Does the WU happen to be Test protien A?
still cant get this damn thing to work. here is my log file.
it seems it gets the WU attempts to start it, says my machine is unstable, sends results and starts over again. :confused:PHP Code:
07:50:03] *------------------------------*
[07:50:03] Folding@Home GPU Core - Beta
[07:50:03] Version 1.05 (Thu Jun 12 15:39:34 PDT 2008)
[07:50:03]
[07:50:03] Compiler :
[07:50:03] Build host: amoeba
[07:50:03] Preparing to commence simulation
[07:50:03] - Looking at optimizations...
[07:50:03] - Created dyn
[07:50:03] - Files status OK
[07:50:03] - Expanded 42191 -> 246249 (decompressed 583.6 percent)
[07:50:03] Called DecompressByteArray: compressed_data_size=42191 data_size=246249, decompressed_data_size=246249 diff=0
[07:50:03] - Digital signature verified
[07:50:03]
[07:50:03] Project: 5001 (Run 1, Clone 65, Gen 39)
[07:50:03]
[07:50:03] Assembly optimizations on if available.
[07:50:03] Entering M.D.
[07:50:09] mdrun_gpu returned -1
[07:50:09] Going to send back what have done.
[07:50:10] logfile size: 5446 info=5446 bed=25 hdr=1
[07:50:10] - Writing 5984 bytes of core data to disk...
[07:50:10] Done: 5472 -> 1995 (compressed to 36.4 percent)
[07:50:10] ... Done.
[07:50:10]
[07:50:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:50:13] CoreStatus = 7A (122)
[07:50:13] Sending work to server
[07:50:13] + Attempting to send results
[07:50:13] + Results successfully sent
[07:50:13] Thank you for your contribution to Folding@Home.
[07:50:17] - Preparing to get new work unit...
[07:50:17] + Attempting to get work packet
[07:50:17] - Connecting to assignment server
[07:50:17] - Successful: assigned to (171.64.65.20).
[07:50:17] + News From Folding@Home: GPU folding beta
[07:50:18] Loaded queue successfully.
[07:50:18] + Closed connections
[07:50:23]
[07:50:23] + Processing work unit
[07:50:23] Core required: FahCore_11.exe
[07:50:23] Core found.
[07:50:23] Working on Unit 00 [June 20 07:50:23]
[07:50:23] + Working ...
[07:50:23]
[07:50:23] *------------------------------*
[07:50:23] Folding@Home GPU Core - Beta
[07:50:23] Version 1.05 (Thu Jun 12 15:39:34 PDT 2008)
[07:50:23]
[07:50:23] Compiler :
[07:50:23] Build host: amoeba
[07:50:23] Preparing to commence simulation
[07:50:23] - Looking at optimizations...
[07:50:23] - Created dyn
[07:50:23] - Files status OK
[07:50:23] - Expanded 41814 -> 246249 (decompressed 588.9 percent)
[07:50:23] Called DecompressByteArray: compressed_data_size=41814 data_size=246249, decompressed_data_size=246249 diff=0
[07:50:23] - Digital signature verified
[07:50:23]
[07:50:23] Project: 5001 (Run 5, Clone 70, Gen 20)
[07:50:23]
[07:50:23] Assembly optimizations on if available.
[07:50:23] Entering M.D.
[07:50:29] mdrun_gpu returned -1
[07:50:29] Going to send back what have done.
[07:50:30] logfile size: 5447 info=5447 bed=25 hdr=1
[07:50:30] - Writing 5985 bytes of core data to disk...
[07:50:30] Done: 5473 -> 2001 (compressed to 36.5 percent)
[07:50:30] ... Done.
[07:50:30]
[07:50:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:50:33] CoreStatus = 7A (122)
[07:50:33] Sending work to server
[07:50:33] + Attempting to send results
[07:50:34] + Results successfully sent
[07:50:34] Thank you for your contribution to Folding@Home.
[07:50:38] - Preparing to get new work unit...
[07:50:38] + Attempting to get work packet
[07:50:38] - Connecting to assignment server
[07:50:38] - Successful: assigned to (171.64.65.20).
[07:50:38] + News From Folding@Home: GPU folding beta
[07:50:38] Loaded queue successfully.
[07:50:39] + Closed connections
im back on stock clocks by the way. maybe i should reformat?
nope isnt working
will need to get the modded drivers..will do it this weekend
Yesterday, I installed GPU2 on my folding rig. Had some problems getting it to play nice with my dual SMP clients. I think I have that resolved - but the performance is pretty bad running alongside the dual SMPs (about 434 ppd), so it looks like I need to do some tweaking.
This morning, I got it up and running on my main rig.
I will leave the SMP client offline for today and see how it goes, but for now I'm getting 4,233 PPD with no O/C on my GPU. Pretty good!
-Athlon 64 5000+ BE @ 3.2ghz
-8800gt 512
-Vista Ultimate 64
-177.35 w/ modded .inf
-Stock (600/1500/900), OC'd (735/1837/1000)
-5292 ppd
Might overclock some even more since this seems to not be as sensitive as atitool
Is the servers down again? Bastages.
With GPU2 I can push my GPU much higher then in games and stuff without artifacts showing up;) 2016PPD it's good for a 8600GT right?
That's about what I'm getting. I'm getting 2116.80 ppd atm. Crunching for WCG at the same time.
GPU is running at 66*c. I could probably go higher on the clocks. Maybe a volt mod is in order. I need some potentiometers. :yepp:
Until I get a new card that is. I'm wanting a gtx 280, but I'm going to wait for the price to go down and bugs to be worked out a bit if any.
EDIT: BTW, what are your clocks?
Now I'm getting 2065,17 PPD, the card clocks are 715.5/1678/864(core/shader/mem),the card is at 50ºC,what are your clocks?
I'd also would like to go to a GTX280 but it's too expensive,maybe an GTX260 or a HD4870 with it's 1.2(I don't know if it's GigaFlop or Petaflop) and if it works with GPU2
You needed that much core?I'm doing that with only 666Mhz but with my shaders at 1782Mhz,you we're able to push 823Mhz from your 8600GT or you are using a 8600GTS?
I'm running 177.35 drivers.
Speeds: 690/1700/850 (core/shad/mem)
Shaders are the only thing that needs to be OC'ed.
Forget about got an error at 666/1782,maybe another day I'll try at 650/1782
Intel Q9450 @3.4
eVGA 9800 GTX at Stock
177.39 with physics support
-Vista 32 Bit Premium
GPU Client @ 6550PPD
SMP Client @ 2400PPD
Total Near 9000PPD
I have affinity set so that SMP runs on 3 cores and GPU runs on the other core.
I should be getting +10000 PPD by tomorrow because of the PS3 and a few other computers.
I could not get any other NVIDIA driver to install properly with this card. I was very happy to see 177.39 install and FOlding start to work properly.
http://img293.imageshack.us/img293/7...dingom5.th.jpg
