Im I the only one that thinks it looks kewl? ; ) Looks pretty easy to fit alot of Watercooling gear in it. Might just get one of these cases!
for me, looks like some super-duper Cm690........
more than enough......... and the price, well, I'd pay.
probably my next case, too bad it isn't black interior...
After looking at a few reviews I have to say I'm coming around as well, just not sure about all the tool-less stuff(can't beat a good old fashioned screw imo).
case contents
# Stand-offs 20
# #6-32 screws 40
# M3 screw 30
# M47 screw 16
# Wheel 4
# Cable tie 12
# 5.25” to 3.5” converter shield 1
# Extension cable 1
# Buzzer 1
http://www.motherboards.org/imagevie.../1808_p3_2.jpg
i relly like that case. the only cons is that it is so big, and i dont think it will fit under my desk :eek:.
should i buy a new one (desk of course, i'll buy this case for sure :D)?
Stacker 830 is still my best... specially with its side panel modded :up:
A few things...they say you can fit 3x120mm fans up top, but I only see room for 2...where's the 3rd go?
Second, judging by the specs, the 140mm rear fan can also fit a 120?
Third, you guys think the front 230mm fan is easily removable?
This looks like a sweet case, I wanna try building an "extreme" air cooling case, with 10 Medium speed Slip streams:
4x in side panel
3x up top
1 in rear
2 push/pull for TRUE black
(remove all 230's)
Not sure about putting 10x 120's in it but isn't 3x 230s and a 140 pretty extreme to begin with? It's not like they're spinning at 800rpm, they are spinning at 1700rpm. I think they should move a fair amount of air. I have one on order from Directron so I can answer the other questions when it arrives.:D
Axis
Its on newegg 159$ + 30$ shipping.
You are correct. I looked quickly at the Directron specs and it's a little decieving as its listed like this "230x30mm red LED fan x 1, 700 R.P.M". Guess I should pay closer attention, lol.
Mine has been shipped from Directron so they have them in stock as well.
Axis
Cool. It does look like a very solid case to W/C with. Room for a triple rad stock and plenty of ventilation.
Here is a review of the case for those interested. :cool:
http://www.planetx64.com/index.php?o...1375&Itemid=14
I have mine in hand and must say it's very nice. I'm VERY pleased with it and feel like it is a HELLA deal for $160 shipped to your door.
Axis
Now that I have it, I can answer your other questions.
The 3rd top 120mm goes halfway under the cover on the top, you can see the first two holes in the top picture and the other two can be accessed by lifting up the rubber pad. There is a vent in the rear of the cover that exhaust the air from it.
The screws holding the 230s on are a mystery for me or i'm just blind. It doesn't look like a hex and none of my hex bits fit it. I could be a inbetween hex I don't have though. I ended up getting it out with a small square bit I have.
The front 230 can only be replaced by what appears to be single 120. You could probably mod it to take two though.
Axis
Mines Ordered..... I just dont know when it will arrive, I have 5 Project PC's now.... Tho its a sweet Case!
How loud, in your opinion, are the 230mm fans?
