i like internal setups
I say that this case is pretty sweet. Not the prettiest, but it looks great for watercooling.
But damn that thing is tall!
could u swap out the 140's for 120's?
with some creativity, probably. the wider fan cutouts could aid in mounting rads closer the front of the cases without modding.
I would keep the Lian LI Rocketfish for $50 :up:
Same space, same finish but less complicated blemishes inside.
Thumbs up for using 140mm fans :up:
Ill stick with my stacker stc-01 tho...
honestly this case will be a :banana::banana::banana::banana::banana:. Heres my reason why.
The bottom looks like only a 3 drive stack cage, so it means probably just enough room for a 120mm fan. Which means you cant use thick or large class rads down there, because there slightly wider then a 120mm fan.
The top has side mounting drives, but the holding system is very unique. Its gonna make fitting a rad up there very difficult as well.
So your limited on the bottom and limited on the top. WTF does this system have 4 PSU mounts for. Im kinda lost on this.
The 4 tube areas in the rear as someone said expected this unit to be a externally cooled unit if you used water. That being said, disrupt, i think you should look at the 343B instead. You'll probably be a lot happier.
don't you have a v2k to work on disrupt >:(
NaeKuh: 4 PSU mounts ? Where ??
2 top, 2 bottom. Count them. :ROTF:
The top 2 go regular style.
The bottom 2 go sideways.
See i count 4 total.
Blah:
The following errors occurred with your submission:
This forum requires that you wait 70 seconds between posts. Please try again in 16 seconds.
^ makes it hard for me that only has like 10-15 sec inbetween each break. :\
Yo bro, my advice, get a koolance 120x4 shourd and top and use that to house the rad. As i see it now, its gonna be tough to fit everything internally and spec it to the way you and i usually have it.
I only count one, see attached picture.
So big, yet so hard to fit everything internally. I don't see where to put a pump in a good spot without making routing a mess.
I think you had your modding glasses on, you saw where PSUs could go. ;)
It is unfeasibly tall but I like it anyway.
I want that case, im so tired of my case now. I want one with the depth like that. My case looks like a darn box car under my desk. :rofl:When will it come out?
http://www.specialtech.co.uk/spshop/...cat=738&page=1
stick one of those 140x3 rads in the front
you'd probably be happier with a LianLi A77 case...
video tourhttp://www.truveo.com/TYR-PCX2000/id/3789634145
has some potential, but i think theres a lot of other cases that are much better for w/c than this. damn loooks sexy tho.
