Yeah, the only thing I don't like about that block is the pins, should have gone with the tapered triangular pins they use in their CPU blocks. It would have given more surface area and kept the restriction low.
Victor i have run into corrosion.
And ive used only innovotek coolant.
Also Phelan ran into corrosion on the mil spec GTX. :T
Mix Alu ,and your playing russian roulette. You may get lucky, however when you dont, it comes out bad.
:T
