updates?
updates?
The sunbeam tools er are SH**, i use an pin remover from AC Ryan, it fits perfectly but dont use much force, because it will break
I belive i will get some work done this week, because i got some time from job from my new job as Server King
Wow I really like what you did the PSU-Express cable. I managed to removed my PCI cable with the Sunbeam, but it took a very long time; and thats with only four cables. To think I was going to do it with my PSU cable was not welcoming. I really like the aestetic look to it, now that you metioned about the AC Ryan, I'm definitely put it on my list to do. Now *runs off to PPCs*.
BTW looking good on the project keep it up :up:.
i <3 cosmos s case look so nice painted black and chrome rails along with a nice window nothing else will come close imo. now when you painted your case you get it powder coated or just use a spray can?
did you sand the plastic panels then paint or sand, primer then paint over that?
None of your pictures are showing up....imagehost down?
Nice sleeving
updates?
nothing new?
An very sad update:
I ran into alot problems while modding different things, while trying to do some fancy stuff with power button (I/O Panel) it broke and coolermaster does not any for sale yet, atleast what the CoolerMaster Shop told me
Also while polishing the sidebars at the front, one of the springs holding it where lost, and i also have to desambly the case for better asembly because the sides doesnt fit properly so the side keeps "popping" off the case, really ignoring
So now i stopping modding it and put it back in the box, maybe i will finish it in the future but who knows :)
Well you could always email cm and a sk for a replacement part. Just make sure that the thing is within warranty ;)
Also about the sidepanel make sure there is no cable on the actual spring system from the outside where it touches the sidepanel.
(of course if that is not the window panel)
Also make sure you only have a cable on a line and not 1 piled up on another.
also try no to use the downer hole of the case for the psu cables use the upper one
Hope to see more of your mod
dont give up....CM will send you a replacement part, they sent me a new side panel after I dented it trying to force it back on... (cables were in the way) It was all my fault but they replaced it anyway.
looking great for now! :up:
