The problem is i dont have another mortherboard with pcie or even a intel cpu socket 775 or DDR2
I know it isnt my PhysX or the Sound card had then working in older machines
Will have to try everything else in a friends comp this week whilst waiting
YAY finaly some progress :d
Just order some more parts to get this nuild finished as my new motherboard arrived today :d
Changing my EK res 100 to another EK-DDC EK-Res 100 so both shall be mounted ontop of ther intake fan :d
Got some Silverstonetek PCI vents.
Tom at ChilledPC is going to reduce my 3*8800 tops down from 13mm to 10mm therefor making then single slot EK block whilst also counter sinking holes in the tops :d GO TOM
if all goes to plan, lots more picies tomorrow and a nice finished system minus my 3*8800's
That's some extra TLC you got there :D.
When are you expecting to have your build finished? End of the month?
We want piccies !!!
As soon as Tom get my block tops back after some milling done on them, so :d, so yeah end of months for 100% completion
Carn't wait now
nice work
and the over all looks nice~
Ok, Hey guys.
I need some major advice now as to where to head with this build...
I'm not currently liking my setup with how its looking so far...
I'm thinking of changing my dual loops:
RES > DDC 18W > 120.1 > 120.1 > EK Supreme > 120.1 > Mofset > Mofset > S-Max > EK 780i SB > Maze 4 (PhysX)
RES > DDC 18W > 120.3 > 8800Ultra > 8800Ultra > 8800Ultra
I'm now looking at doing 3 loops as follows:
RES > DDC 18W > 120.1 > 120.1 > EK Supreme (1/2")
RES > DDC 18W > 120.1 > Mofset > Mofset > S-Max > EK 780i SB (3/8")
RES > DDC 18W > 120.3 > 8800Ultra > 8800Ultra > 8800Ultra > EK GPU-Supreme (PhysX) (Unknown/Unknown")
Also going to get some heat srink tape and wire sleving and cover all my cables, is it worth the effot though?
Still awaiting my gpu tops back from Tom (Chilled PC) as he is now sourcing a some new screws and counter sinking the holes at the same time as reducing the block top thickness to make them true single slot :)
any updates?
what did you use to mount the rad on the top panel?
Nice work! I'm looking to do something similar with my TJ09. How far does the 360mm rad hang over the 5.25" bays? I'm guessing you can't use the top two bays with the radiator there.
