Fried Chicken's "murderMod" TJ07
Hi all,
Fried Chicken asked me to make a worklog of his build so here we go. Please go easy on me as this is my 1st attempt at a worklog. I’ll try to focus on the stuff that I think may be of interest and not so much on the obvious. I’m not accustomed to taking photos while I work so if I omit anything that is of interest, please don’t hesitate to ask and I’ll answer your question as best I can. Alright, enough with the flapping of gums, on with the build. :)
It all starts with a Hammond 1591A project box. I’m a gonna build the whole system inside it.
http://murderbox.com/uploads/FC02_051b.jpg
Kidding… I use these for a bunch of stuff; they’re really cheap and to start with, make great radiator platforms.
http://murderbox.com/uploads/FC02_011b.jpg
I love that each one comes with an inspected by card – how often do you see that on a $3.61 product!
http://murderbox.com/uploads/FC02_013b.jpg
They also come with a set of screws that I'll use to secure the boxes to the base of the case.
http://murderbox.com/uploads/FC02_006b.jpg
I use the box lids as guides to mark the holes…
http://murderbox.com/uploads/FC02_008b.jpg
A drill bit works well for marking the hole locations. I twist the bit between my thumb and forefinger a few times and presto; marked for drilling. Which reminds me – have you heard the title for Steven Segal’s upcoming straight to DVD movie – Marked for Discount. I know… don’t quit my day job.
http://murderbox.com/uploads/FC02_005b.jpg
One set of holes drilled and one to go…
http://murderbox.com/uploads/FC02_016b.jpg
On the underside I countersink the holes so the screw heads are flush.
http://murderbox.com/uploads/FC02_039b.jpg
Rad mounts installed. I sand the tops to to help the tape adhere… yes, tape…
http://murderbox.com/uploads/FC02_044b.jpg
I use 3M heavy duty mounting tape to attach the radiators to the mounts. The stuff sticks like poop to a blanket. You know this as fact if you ever have to separate something attached with it. Errrr… the tape… not the poop.
Ok, time for a slight deviation before finishing the rad mounting. I do a little something and now’s the time – before the rads are in place.
http://murderbox.com/uploads/FC02_058b.jpg
I start by separating the wires from the front PCB and then wrap them in two sleeves.
http://murderbox.com/uploads/FC02_045b.jpg
Next, I make a slight alteration to the front LED’s – I find them too bright so…
http://murderbox.com/uploads/FC02_049b.jpg
I cover them with small pieces of red gaffer’s tape. Now instead of bright blue, they’re a nice subtle purple.
http://murderbox.com/uploads/FC02_053b.jpg
Time for another Hammond 1691A project box! (ok, the exclamation was overkill). Holding the PCB as a guide, I drill two holes…
http://murderbox.com/uploads/FC02_059b.jpg
I mount the PCB using only the bottom two holes…
http://murderbox.com/uploads/FC02_063b.jpg
Using these 10mm M3 screws…
http://murderbox.com/uploads/FC02_066b.jpg
I attach the project box over the front PCB. Oh, I forgot to mention that I drill a hole in the side to pass the sleeved wires…
Ok, now it’s back to the rads…
http://murderbox.com/uploads/FC02_068b.jpg
I wire up and install the fans…
http://murderbox.com/uploads/FC02_087b.jpg
Finally it’s time to stick the rads to the mounts. I’ll repaint the top of the rads later (You’ll see that scratch on the PA120.2 through an opening in the midplate).
http://murderbox.com/uploads/FC02_079b.jpg
Other side…
http://murderbox.com/uploads/FC03_012b.jpg
The gangs all here… Rads, pump and PSU. It’s a tight fit but fit it does.
http://murderbox.com/uploads/FC03_042b.jpg
Next I check the rad fittings for leaks by run a mini loop… or as some call it a loopette.
No leaks… joy.
http://murderbox.com/uploads/FC03_014b.jpg
Time to test-fit the midplate and mark hose locations for drilling.
http://murderbox.com/uploads/FC03_031b.jpg
This is when I start praying that when I drill those 1” holes, I don’t fark up the finish. Sure I could mock up the build, drill the holes then have it powder coated but where’s the “live by the seat of your pants” thrill in that?
http://murderbox.com/uploads/FC03_039b.jpg
Nice and clean down below on this side…
http://murderbox.com/uploads/FC03_025b.jpg
Ack! not so much this side. It’s going to take a lot of cable management to get this rat’s nest sorted and it’s going to get a whole lot worse before it gets better – I’ve yet to break out the 24 pin mobo power cable into individual sleeves. Actually multiply that by two since I’ll be doing the same for all 4 PCI-E power connectors. All told, I’ll have roughly 65 cables to deal with. :eek:
Well that’s all for today – next step is to power it up and load windows… oh wait; I think there’s a few bits to go before that.
The next time you see me I’ll have drilled the hose holes in the midplate and done all the PSU sleeving. The next installment will be focused on the upper chamber loop.
Until then - Thanks for stopping by. :)
