I've never actually fried anything with a WC accident. I recently came close, though. Had water leak onto my video card, got underneath the unisink and started to what looked like corrode some small SMD parts. I was only alerted to the problem when my video all of a sudden turned to garbled mess and I could no longer boot into windows. Ironically, this happened right in the middle of stress testing a new overclock, which made things worse because I thought the problem was with the CPU or something.
I only discovered what had happened when I disassembled my PC and noticed a tiny bit of wetness by a barb, that was right above the video card.
Took it out, took all the sinks off, and cleaned it with contact cleaner very thoroughly and scrubbed off the corrosion with the contact cleaner and a toothbrush. Amazingly, it now works good as new.
The only other major accident I had was when I first got into watercooling. I punctured a PA120.3 with a screw that was too long. Quite an expensive accident :( Needless to say, that has not happened since :)
