that'll work (by chimney breast you mean the space between the sheet rock room walls & the bricks if the chimney tower ) mine is about a foot all the way around the tower = attic to crawl space in other words i can see the dirt floor of the crawl space from the attic by looking down the space where the chimney is
I got a chimney breast behide the wall of the room that the PC will be in
thats where i'll be running the pipe work up/down & the service line for the 30 amp service down as that will come from the service box in the gagrage then up into a run in the attic to the chimney breast an quad outlet at the PC level & an quad outlet at the blower & pumps in the crawl space
planning on a huge resevior on the loops out lines of the PC on that same level as the PC = I'll get a 7 foot drop',,,,
planning on PVC pipe about 10 t0 8 inches wide & then just keep reducing down the size with reducers to 1 1/2 pipe then tee it back into two loops agin reduce agin into the rads that way i'll get water pressure to the rads in the crawlspace by gravity :D & by reducing the pipe size in incurments that increases the water pressure with no pump , then it's into a pair of pumps straight outaa the rads up & 2 more pumps at the PC into the water block loops for MAX flow
