After months of no spare time to spend on the Mach restoration, the unit is now finally done:
http://shrani.si/t/2l/on/4HrhMUU5/dsc0558.jpg
Sloppy me - burned through copper pipe due to thermal load of acetlyene/O2 torch flame:
http://shrani.si/t/2q/pT/14OeoaGc/dsc0559.jpg
Brazed evap Maze GT1:
http://shrani.si/t/2n/wY/1qen0lCa/dsc0560.jpg http://shrani.si/t/32/ut/3Ung2FRw/dsc0561.jpg
System running while charging. The manifold is a bit f$$ked up, so the low side port is attached to high side manifold's port:
http://shrani.si/t/3V/6k/4JduHQFr/dsc0562.jpg http://shrani.si/t/X/F5/37hCc9JW/dsc0564.jpg http://shrani.si/t/2F/Mu/qRcVkJ7/dsc0565.jpg http://shrani.si/t//Yo/3rllpvfp/dsc0567.jpg
-62°C but unstable, -72°C was achieved for a second or two before the compressor shut down :)
http://shrani.si/t/2e/oi/2kHH47OZ/dsc0568.jpg
The unit is faily overcharged, but the pull down is mega fast - about 20-25 seconds from +20°C to -40°C, perhaps due to evaporators really low mass. The report on the temperatures will probably be tommorrow because i still have to find the optimal charge for it.
