That's exactly like the pic. The other point doesn't have to be the screw, red dot to any ground will do.
Easy vGPU measurement points can be found in the pic in post #15. There's 2 rows of surface mount ceramic caps behind the GPU. Each cap has two tin ends of which one is a vGPU measuring point (the other being ground).
Suur-kiitos Xargo:lle!
I have now 3x GeForce 9800 GTX (Thanks to Gainward!!)
Going to voltmod all of them to cool with Dice.
I run already some 3-way SLI benchmarks on Stockcooling without Voltmod:
http://www.hwbot.org/result.do?resultId=724049
525Ω Poti -> 13,0Ω total -> 1,24 Volt
Ok I am blind, can some one post pic with two spots for VGPU measurement, just two spots. Thanks in advance.
From post 15:
http://shrani.si/f/2t/Eu/4DFq8Vki/image07.jpg
One side of each of those SMC's is GND, and the other side is vGPU.
Thanks ;)
So how much voltage is safe at stock air ?
Grab the voltage on a vertical resistor.
Some horizontal resitors do not have Voltage on system boot e.g.
I'm running 1,35V on air with 2x 80mm-Fans.
Mount a vacuum cleaner at the back and you get better Temps approx. -5 to -10 degree Celsius less.
Or put the Stockfan to 100% with RivaTuner: 1,35V no problem.
Going thru the threads or volt modding.. does anyone have a volt mod for the memory yet? inc. guide w/pics?
thanks in advance!
Anyone happen to bump into a practical vDDQ (~2.00v) measuring point?
The Delta inductor on the frontside is a bit inconvenient... I can't find one because I don't have the card but I need the point for making the vDDQ mod guide.
bump to keep this thread up, I'm going to try this out next week ;)
Shamino told me that there is a VMem-Mod somewhere at VR-Zone, but I did not found it until now.
So anyone can tell what was the final resistance for 1.35-1.38v?
Just got me this card, got to wait till mcw60 comes back in stock on newegg..
ETA 4/30
:D
Any progress on vmem?
thanks for the mod!
running 870/1200/2000 on stock fanspeed 100%mod
17,600 3dmark06 on q6600@3.8ghz
should have my ek waterblock in 2-3days!
il let you guys know when i hit 1ghz stable ;)
**not scared!**
wen i connect the 500ohm resistor does the screw start from the left position so i turn it clockwise to increase voltage or does the screw start from the middle postion, turn clock wise to increae and anti clock wise to decrease the voltage.
http://i146.photobucket.com/albums/r...i379/screw.jpg
I hope that makes sense guys. :confused:
Am so noob never done this kinda mod b4, just want to be clear dont want to kill anything.
On the pots I use, clockwise is increase voltage (lower resistance).
Time to break out the multimeter mate..
Never-ever volt mod if you don't have a multimeter.
so hows about this vmem mod?
Sorry, seems I forgot to post memory vDD and vDDQ mods! :p:
Caution, these mods are untested.
Here's vDD (= vMEM):
Attachment 77867
And vDDQ (= "the other vMEM"):
Attachment 77868
Measuring points:
Attachment 77869
PS. I know there are easier vDD (dunno about vDDQ?) measuring points on the backside but it's summer and I'm too lazy to draw the diagram. :p:
Kyllд!
Is it summer already?
Anyway, great job, let's see someone getting results with this... I'm still waiting for my waterblock.
Question: how do we adjust vDDQ? Just bump it about 0.1v and see what happens?
:cool:
vcore is 500kΩ?
jackies,
0.1V vDDQ increase should be safe and give a clue if adjusting it yields something.
fafoylis,
500Ω VR, not 500kΩ. The solder points should measure ~11Ω beofre soldering.
