Hmmm.. some 9800GX2 investigations
Me and Zannema was playing little detectives tonight and we found out, that 9800GX2 might be using same PCI-E overclocking method as 9600GT.
Everything else at same speed. Only PCI-E frequency raise.
First only PCI-E frequency raising. ( everyting else at same speed in every run)
100MHz PCI-E = 76.106
105MHz PCI-E = 77.410
110MHz PCI-E = 78.788
115MHz PCI-E = 80.554
If it uses same pattern as 9600GT, the first frequencys are equal to GPU speeds 600 / 636 / 669 / 709 and so on...
Then we tested little more, but now we raise only GPU clocks:
100MHz PCI-E + 660MHz gpu speed = 78.230 (same as 110MHz PCI-E only)
100MHz PCI-E + 700MHz gpu speed = 79.100 (no score to compare, cause 709MHz is the next step)
Then we do the combination test:
105MHz PCI-E + 630MHz gpu speed = 78.6 (the same score as 110MHz PCI-E or PCI-E 100MHz and gpu 660MHz)
So, these cards are having the same PCI-E overclocking method as in 9600GT. If you set your PCI-E frequency higher, graphics card will automatically overclock.
If this is true, we have to know the exact steps. Or if you use 100mhz PCI-E speed, you can find the limit of your VGA. After that you can calculate what PCI-E speed you can use and how much oc your vga can take after that.
One Rivatuner update please :up:
