Here some pics of the interior painted:
http://img296.imageshack.us/img296/9326/img0349asp8.jpg
http://img177.imageshack.us/img177/9518/img0350aud2.jpg
I finally buy the paint!!!!
I bought Ruster Oleum black and white, and Krylon yellow and red :D
http://img153.imageshack.us/img153/970/img0366aku3.jpg
Cost: the 4 by $72 pesos or u$s 22.65 or 14.20 Euros
And also buy sand of 400 and 1200 grid
Hello, today at 19hs, i pained with white painters touch all the case, internal and external, i'll keep painting tomorrow
Here a pic
http://img214.imageshack.us/img214/4918/img0367aye9.jpg
Hey fella how is it ?
Your work is terrific !! I love how's your case looking like !! Really i hope to see it finish soon. The painting work weel be fantastic.
Salu2
Hello, i'm back :D.
Yesterday my syster printed the Moulds for painting over the case. Today, my syster help me to put the moulds all over the case, to start painting the yellows parts, here pictures of the proccess:
http://img132.imageshack.us/img132/9...arillo2ck1.jpg
http://img132.imageshack.us/img132/8...arillo3so8.jpg
http://img132.imageshack.us/img132/8...marillowz1.jpg
http://img267.imageshack.us/img267/6...marilloee3.jpg
http://img267.imageshack.us/img267/6...aumentoxs2.jpg
http://img156.imageshack.us/img156/1...cortes2jo2.jpg
http://img156.imageshack.us/img156/5...cortes3le7.jpg
http://img156.imageshack.us/img156/5...ocorteswa0.jpg
http://img156.imageshack.us/img156/3...traseromm8.jpg
Now i given the second hand
nice templates should make painting easy, cant wait so see it finished
Thanks man, my syster make the templates, i told, the design, and she makes the templates and pasted then on the case :p: she was a big help with the templates proccess :)
And its really easy to paint with the templates :D
I hope to have a little of time tomorrow so i can paint all the case or at least the red part :)
What are you using to hold the MDF together? I thought screws would split the MDF.
Hello, i use screws self, first i make a hole where i want to put a screw with a 3mm wick, then i put some Glue on the holes of every screw and then i screwed the screws, so with the glue and the hole with the screw its keep really tight. :D
If i wont do the hole first, the MDF split, so first do a 3mm hole, and you wouldn't have any problem :D
I put our the templates of the yellow paint, it's keep from this way:
http://img376.imageshack.us/img376/5...800x600gt9.jpg
http://img138.imageshack.us/img138/1...800x600ew8.jpg
Here some pics of the first hand with Red:
http://img249.imageshack.us/img249/8...800x600tr7.jpg
http://img253.imageshack.us/img253/7...800x600wj2.jpg
http://img166.imageshack.us/img166/3...800x600bz4.jpg
hi the screws have 18mm, if you back the other page you will see that where its goes the head of the screws, i make a little big hole of 3 mm of deep and the with of the head of the screw, so the screw keep a little inside of the MDF, then i fill with glue more sandust over the screws, and the screws dissapear, then i sanded over the glue and sandust, and the wood keep plain :D
Look the pictures and you will see and undestand
Sorry for my english :D
Color theme is looking good and unique. Keep it coming!:up:
Thanks man. Today, I take out the red templates, here pictures, it;s only left the black paint, and then see the details, and the nick letters :) and others small stuff
http://img440.imageshack.us/img440/9...800x600ew9.jpg
http://img440.imageshack.us/img440/3...800x600zi3.jpg
Looks nicee i like wooden cases:D
Niiiice
whats the size of the fan on the top? 14cm?
i want to see it painted, very unnusual but beautiful paint scheme
Hi, finally after a bad lesson, i learn that yellow Krylon and black Rust Oleum, wont look to be compatible, now the problem have been solved, here the final painting results:
http://img171.imageshack.us/img171/8...800x600vt8.jpg
http://img329.imageshack.us/img329/7...l800x60yi5.jpg
http://img405.imageshack.us/img405/2...800x600eu8.jpg
http://img171.imageshack.us/img171/8465/4800x600qt7.jpg
http://img405.imageshack.us/img405/4435/5800x600qj3.jpg
Excellent work. I really like the paint design.
Hi, today I install the front USB and sound.
I made the reset and power buttons, install both, but only make the button for the reset, now left to make the power button, my nick letter for the side, and buy silicone to make the legs and put beetween the fans and the wood, and all over the DVDrw and the hdds, so all the vibrations will gone :D
http://img237.imageshack.us/img237/4...800x600ka4.jpg
http://img237.imageshack.us/img237/4...800x600bi4.jpg
http://img231.imageshack.us/img231/8...800x600va7.jpg
http://img381.imageshack.us/img381/8...ado800xac0.jpg
