...I havn't sent anything because I didn't do a vmem mod. Dunno where you got that idea. What kind of 3dmark scores are you getting with your card?
also, you should be able to take it higher then 270, especcialy with a voltmod.
youst five minutes ago i finished a 3dmark2k1 test on 270gpu and 286ram (that is default). I`ve only got 2183!!!You see this card is all ram and no gpu! But the problem is that i cant raise ram over 320!!I thought its overheating so I added 2 80*80 mm fan on the rams cooling ribbs:) perfectly cold, but no results??any idea why??? Could you ran a gpu270 and default ram 3dmark an tell me the score.. I tink i got a little confused, and i probably read a post, thats why have seen a vmod for rams
yikes, only 2183. Is the 286 on the ram before the ddr effect or after?
What kind of computer have you got?
On my old 733@825 at 265 core and probalby around 235 ram I got 2330 :(
A friend of mine droped by with a 15" monitor... He said, if I coud test it, if it works. I plug it, i turn my computer on, and everything is purple!!Then i plug my monitor back on, and IT`S STILL PURPLE!!!!! I take it to my secound computer, the same!! The stupid monitor f* two of my graphic cards!!!Any ideas??? I dont want to play ut2k3 all purple, or with an pci card... oh yeah, if cops ask, i did no killed my "friend"
probably a problem with the connector, you're probably screwed...
Try hitting your friend with a bat, and then taking his money. You might also want to try getting him to try it on his stuff, to see if the purple affects his stuff aswell.
hah, I love playing ut2k3 aswell.
turnament rulz...oh the monitors are fine...but graphic cards are wrecked
so godbye geforce an hello radeon 9500, softmoded to 9700 and overclocked, maybe i can aki it to the 9700pro with a vmod..
I know its probably a little late now, but theres probably a slight chance for RMA, as long as you can remove the volt mod and stuff.
Also, look into the 9800se > 9800 pro mod, instead of the 9500>9700pro.
what is rma???
hey, i finnaly got around to doing the voltmod. I used a 120ohm, but i will deffinitly try switching it with the 100 and the 80 i found. It got from from a very unstable max of 270 to a very unstable max of 280. It doesn't really like being run at 270 normally though, after about 2 hours of ut2k3 it started glitching up and then finnaly gave me red lines going down the screen. So the voltmod does work, check your cooling.
as for your question rma stands for Return Merchandise Authorization. Basicly where you send the card back to the maker and they exchange it or whatever.
